If you need to get the job done, the SP 150 is the printer for you. Designed to make you more productive, its simple installation process and 22ppm output means you can enjoy its reliability, intuitive operation and sleek design, almost straight out-of-the-box.
Its simplicity means you can get on with what you need to do, safe in the knowledge that all your printing needs are taken care of. No matter if it's home or small business print requirements.
- Ricoh SP 150 - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 6.5 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 22 ppm - max speed
- Max Resolution (B&W)
- 1200 x 600 dpi
- Interface
- USB 2.0
- Language Simulation
- Windows GDI driver
- Media Type
- Plain paper
- Total Media Capacity
- 50 sheets
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / XP / 7 / 8 / 8.1, Windows 10, Apple MacOS X 10.8 - 10.11
- 2-year warranty
- 35.1 cm x 26.6 cm x 10.6 cm
- Printer Type
- Personal printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 1200 x 600 dpi
- First Print Out Time B/W
- 11 sec
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 105 g/m²
- 50 sheets
- Media Feeders
- 1 x automatic - 50 sheets
- Connections
- 1 x USB 2.0
- Consumables Included
- 1 x toner cartridge - up to 700 pages ISO/IEC 19752
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 350 Watt
- Power Consumption Sleep
- 1.2 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years
- 35.1 cm
- 26.6 cm
- 10.6 cm
- 6.5 kg
