More compact. More productive. More options.
In today’s marketplace, reliability and productivity is key, and you need a device you can count on. Of course, you want value for money too. So the SP 400DN is the perfect solution for small workgroups, cost-effective printing for a low-upfront cost. And featuring a 30ppm speed, it’s so compact, it could fi almost anywhere in your offie environment. With a 360,000 print lifetime and the ability to support a range of different paper thicknesses, you get the longevity you need, combined with the flxibility to do much more.
- Can be positioned in limited spaces so it’s perfect for any office
- User-friendly with 4-line LED display panel so it’s easy to use
- Supports Smart Devices for mobile printing via our dedicated applications
- Handles standard offie and thick paper types from any tray
- ECO friendly, low power consumption through LED technology
Easy to print. From almost anywhere.
Enabling more, from less.
Our technology is designed to make every function you need easily accessible. And we’ve made sure this device is seamless to work with. The 4 line LED display panel gives you clear instructions and visual prompts, so you can focus on the task inhand, and just get the job done.
Print direct from your mobile.
You can print images, documents and more using the Ricoh Smart Device Print&Scan app from your Apple iPhone, iPad and Android Smart Devices. All you need to do is download the app and be on the same network. It’s really that simple.
Advance your business.
The technology behind the LED print-head not only improves quality, but enables it to be much smaller than traditional laser solutions. So you can put this capable device in a corner – or on a desk – of your company or home offie and it will take up minimal space, but keep on performing.
More options for print. And better for the environment.
The sheer range of paper stock it can handle means you have the ability to print on various kinds of papers and from any tray. It can print on thin paper to 162g/m2 thick paper, so there’s no wastage. And it even has low-power consumption with LED technology so your costs can be lower and it’s ECO friendly too.
Technology: LED
Warm-up time: e 14 seconds
First output speed: 6.5 seconds
Print speed: B/W: 30 pages per minute
CPU: Intel Celeron-M: 500 MHz GHz ARM Cortex A8
Memory: Standard: 256 MB GB
Maximum: 256 MB GB
Duty cycle: 50,000 prints per month
Duplex: Yes
Dimensions (W x D x H): 370 x 392 x 268 mm
Weight: 14.5 kg
- Ricoh SP 450DN - printer - B/W - LED
- Printer Type
- Workgroup printer - LED - B/W
- 15.6 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- PMC-Sierra RM7035C 533 MHz
- RAM Installed (Max)
- 512 MB (1 GB)
- Card Reader
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF
- Media Type
- Envelopes, plain paper, recycled paper, thick paper, thin paper, preprinted paper
- Total Media Capacity
- 600 sheets
- Monthly Duty Cycle (max)
- 150000 pages
- Networking
- Print server
- System Requirements
- HP-UX 11.x, SunSoft Solaris 9, HP-UX 11i v2, SCO OpenServer 5.0.7, SunSoft Solaris 10, Red Hat Enterprise Linux 4, SCO OpenServer 6, IBM AIX 5L 5.3, HP-UX 11i v3, Apple MacOS X 10.5 or later, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Microsoft Windows Server 2012, IBM AIX 5L 6.1, IBM AIX 5L 7.1, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
- 37 cm x 39.2 cm x 30.6 cm
- Printer Type
- Workgroup printer - LED - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 5 sec
- Fonts Included
- 45 x PCL , 13 x Intellifonts , 136 x PostScript 3
- Processor
RAM
- 512 MB / 1 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 52 g/m² - 162 g/m²
- 600 sheets
- Max Media Capacity
- 1600 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 150000 pages
- Networking
- Print server
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 , 1 x USB host - 4 pin USB Type A
- ISO 9001, ISO 14001, ISO 27001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1100 Watt
- Power Consumption Sleep
- 0.56 Watt
- OS Required
- 37 cm
- 39.2 cm
- 30.6 cm
- 15.6 kg
