With its easy-to-use 4-line LCD operating panel, the SP 211SU is a user-friendly, compact multifunctional device. Speeding at 22 pages per minute, this MFP is ideal for offices in need of high productivity. ID Card Copy is another time-saving feature allowing you to copy both sides of an ID card onto one side of paper. With a resolution of 1,200 x 600 dpi, output is professional at all times. A wealth of benefits for such a compact device!
- Ricoh SP 211SU - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 pages
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 22 ppm
- Max Printing Resolution
- Up to 1200 x 600 dpi
- Scanning
- 600 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Media Size
- Media Type
- Plain paper
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0
- Power
- AC 230 V (50/60Hz)
- 40.2 cm x 36 cm x 25.2 cm
- 9.9 kg
- Microsoft Certification
- Compatible with Windows 7
- Laser - monochrome
- 20000 pages
- Interface
- USB 2.0
- Standard Memory
- 8 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 22 ppm
- Printer Drivers / Emulations
- Windows GDI driver
Scanning
- Optical Resolution
- 600 dpi
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 105 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- 150 sheets
- 1 sheet
- 50 sheets
- Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet weight: 60 g/m² - 105 g/m² , Output tray - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , ADF weight: 52 g/m² - 105 g/m²
- Speed Details
- Printing: up to 22 ppm
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2
- Voltage Required
- 400 Watt
- Power Consumption Standby
- 65 Watt
- Power Consumption Sleep
- 5 Watt
- Warm-Up Time
- 25 sec
- First Copy Out Time B/W
- 10 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- 40.2 cm
- 36 cm
- 25.2 cm
- 9.9 kg
