Ricoh Aficio SG 3110SFNw Colour Geljet Multifunction Printer
Quicklinx: 8KN0WS00 Mfr#: 980668
This user-friendly MFP features a small footprint, full front access and wireless connectivity, making them ideal for retail and office environments where space is limited. With speeds up to 29 pages per minute, these compact MFPs offer high performance copy, print, scan and fax functionality.
The SG 3110SFNw feature Ricoh's fast-drying Liquid Gel technology, which delivers high quality color prints that cannot smudge and are water and sunlight resistant. Color prints are delivered quickly in 6.5 seconds and the standard and optional paper trays enable efficient, uninterrupted print runs. Extended networking is another feature, and there is support for the IPV6 Internet protocol and multiple operating systems.
  • Fast-drying Liquid Gel technology
  • Ongoing commitment to the environment
    As with all Ricoh products, the SG 3110SFNw reflects Ricoh's ongoing commitment to the environment. It has several environmentally responsible features such as low power consumption, a partially recyclable plant-based plastic chassis and toxic free materials. Further savings come from Ricoh's enhanced technology that reduces gel consumption and enables color printing at a similar cost to black and white using economy color mode. The SG 3110SFNw is also Energy Star compliant.
Ricoh SG 3110SFNw - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Ricoh GelJet - 4-ink
Max Copying Speed
Up to 29 ppm (mono) / up to 29 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 3600 x 1200 dpi (mono) / up to 3600 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Original Size
A4 (210 x 297 mm) (max)
Media Size
Media Type
Plain paper
Standard Media Capacity
250 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi
AC 230 V (50/60Hz)
39.9 cm x 43.65 cm x 32.95 cm
15.3 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified, Blue Angel
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
USB 2.0, LAN, Wi-Fi
Standard Memory
256 MB 256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Preset Enlargements
141%, 200%, 100%
Preset Reductions
50%, 71%, 93%
Maximum Copies
99
Automatic Duplexing
Printing
Inkjet Technology
Ricoh GelJet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PCL 5c, Ricoh RPCS
Automatic Duplexing
First Print Out Time B/W
5.5 sec
First Print Out Time Colour
7 sec
Scanning
Optical Resolution
1200 x 1200 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
250 sheets
Max Media Capacity
850 sheets
100 sheets
Speed Details
Copying: up to 29 ppm - B/W , Copying: up to 29 ppm - colour , Printing: up to 29 ppm - B/W , Printing: up to 29 ppm - colour
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.5 or later
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
54 Watt
Power Consumption Standby
4.2 Watt
Warm-Up Time
35 sec
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Blue Angel Compliant
39.9 cm
43.65 cm
32.95 cm
15.3 kg
