Razer Universal Quick Charging Stand for PlayStation 5 - Midnight
Quicklinx: GY78WS00 Mfr#: RC21-01900200-R3M1
Colours:
If you’re looking for the fastest way to keep your PS5 DualSense wireless controller? at prime power levels, then go for the perfect pairing with the Razer Quick Charging Stand.
Able to fully charge your controller in under 3 hours, the stand is also designed with? overcharge protection to prevent overheating and short circuiting.
Easily mount your controller and never worry about the charging stand falling over thanks? to a design and stable build that perfectly seats the PS5™ DualSense™ wireless controller.
To perfectly suit your setup, this charging stand shares the same striking colors as the galaxy inspired DualSense™ wireless controllers.
Simply hook up the charging stand to your PS5™ console, PC, or compatible wall plugs (sold separately) to get powered up and start charging.
  • Quick charge
    Able to fully charge your controller in under three hours, the stand is also designed with overcharge protection to prevent overheating and short circuiting.
  • Curved cradle design
    Easily mount your controller and never worry about the charging stand falling over thanks to a design and stable build that perfectly seats the PS5 DualSense wireless controller.
  • Matches your PS5 DualSense wireless controller
    To perfectly suit your setup, this charging stand shares the same striking colors as the galaxy inspired DualSense wireless controllers.
  • Powered by USB
    Simply hook up the charging stand to your PS5 console, PC, or compatible wall plugs (sold separately) to get powered up and start charging.
Razer charging stand
Charging stand
Wireless game controller
120 mm x 60 mm x 75 mm
245 g
1-year warranty
Sony DualSense
Charging stand
120 mm
60 mm
75 mm
245 g
Enclosure Colour
Compatible Game Consoles
Sony PlayStation 5
Limited warranty - 1 year
Sony DualSense
