The Razer DeathAdder is the world's first 3G infrared sensor gaming mouse. This ultimate gaming mouse with ergonomic right-handed design provides maximum comfort during intensive gameplay, and will send enemies scurrying for cover.
- 63g / 64g Ultra-lightweight Design No deadweight: Made more than 25% lighter than the Razer DeathAdder V2 Pro, enjoy a level of speed and control favored by the world’s top players with one of the lightest ergonomic esports mice ever created.
- Refined Ergonomic Form Optimized for unrivalled handling and comfort: Developed in partnership with top esports pros, the iconic shape of the Razer DeathAdder has been further improved to continue its legacy of award-winning handling and comfort.
- Razer Focus Pro 30K Optical Sensor Best-in-class precision: Razer’s brand-new sensor provides flawless tracking performance on a wider variety of surfaces including glass—supported by intelligent functions for enhanced aim and control
- Razer Optical Mouse Switches Gen-3 No double-clicking issues. No debounce delay: From an improved 90-million click lifecycle with zero double-clicking issues, to a blistering 0.2ms actuation with no debounce delay, the mouse has the reliability and speed built for esport
- Razer HyperSpeed Wireless 25% faster than other wireless: With a connection 25% faster than any other wireless tech available, enjoy high-performance, low-latency competitive play that remains smooth and stable even in noisy wireless environments.
- Up To 90 Hours of Battery Life No gaming downtime: With a smaller, lighter battery that boasts greater power efficiency, this wireless ergonomic esports mouse can run for up to 90 hours of continuous play and is rechargeable via USB Type C.
Manufacturer Warranty - 2 Years
                Zero excess, full performanceWith its incredible weight optimization, the Razer DeathAdder V3 Pro is a lighter ergonomic esports mice - all while improving upon its user experience.
                Upgradeable to true 4000 Hz wireless polling rateExperience a faster wireless performance ever with the Razer HyperPolling wireless dongle. Unlock a standard of responsiveness with the ultimate upgrade for the advanced mice, to secure the speed you need for top-flight competitive gaming.
                Unlock ultra-fine adjustmentsEnable asymmetric cut-off to individually set a lift-off and landing distance that's tuned to your playstyle - with 26 granular levels of height adjustment compared to only 3 in the previous version.
                On-mouse DPI controlCapable of toggling between 5 DPI stages without the need for software, you'll always be ready to compete anywhere with this highly portable, ultra-lightweight esports mouse.
                Onboard memoryThe mouse stores and uses its last used Razer synapse profile, including all calibrated settings suchas: DPI, polling rate and lift-off distance.
                Razer hypershiftEffectively double your inputs at the touch of a button, as you activate an additional set of custom keybinds and DPI stage on the mouse.
- Razer DeathAdder V3 Pro - mouse - Bluetooth, USB - white
- Mouse - ergonomic
- Connectivity Technology
- Wireless - Bluetooth, USB
- White
- Orientation
- Right-handed
- 6.8 cm x 12.8 cm x 4.4 cm
- 64 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 5
- Movement Resolution
- 30000 dpi
- Performance
- 90 million clicks, 70 G maximum acceleration, 750 inches per second
- Gaming
- 5 programmable buttons, Razer Hyperspeed Wireless technology, Razer Speedflex Cable, polytetrafluoroethylene (PTFE) feet, Focus Pro optical sensor, Razer 3rd-gen optical mouse switch, on-board memory profile
- 2-year warranty
- Mouse
- Ergonomic Design
- Orientation
- Right-handed
- Gaming
- 6.8 cm
- 12.8 cm
- 4.4 cm
- 64 g
- White
Input Device
- Wireless
- Interface
- Bluetooth, USB
- Optical
- Buttons Qty
- 5
- 30000 dpi
- Performance
- Included Accessories
- USB dongle, grip tape, USB cable (type-C to type-A) Speedflex, USB dongle adapter
- Run Time (Up To)
- 90 hour(s)
- Limited warranty - 2 years
