Razer Nari Ultimate for Xbox One
Quicklinx: G88JWS00 Mfr#: RZ04-02910100-R3M1
The Razer Nari is the wireless headset designed for supreme comfort. Its auto-adjusting headband is designed to perfectly fit the shape of your head for fuss-free comfort, while the swiveling earcups include cooling gel-infused cushions with memory foam to reduce heat build-up. THX Spatial Audio delivers next-generation virtual surround sound, while Game/Chat Balance in wireless mode provides the perfect mix of game and chat volume. The headset also functions in wired mode with both USB and 3.5 mm analog options. Powered by Razer Chroma.
  • Cooling gel-infused cushions
    Unlike conventional headsets, cooling gel-infused ear cushions reduce heat build-up, while high-density foam with plush leatherette on the rims of the earpads provide the perfect combination of comfort and sound isolation. Hidden indented channels eliminate pressure from glasses for eyewear relief.
  • Game/chat balance
    Game audio will never overpower your team communication again. With the Game/chat balance option available in wireless mode, fine-tune what you hear or simply leave it in the middle for a standard mix.
  • Auto-adjusting headband with swivelling earcups
    The auto-adjusting headband with swivelling ear cups is engineered for maximum adjustability to fit your head to perfection for fuss-free comfort. The unibody aluminium frame ensures that it is lightweight with long-lasting durability.
  • 2.4 GHz wireless audio
    Get lag-free, high-fidelity gaming audio with 2.4 GHz wireless technology. A plug-and-play wireless USB transceiver lets you enjoy a wireless range of up to 12 metres smoothly without disconnection. With audio controls directly on the headset, you can do everything from adjusting volume to muting your mic on the fly.
  • Powered by Razer Chroma
    Customise your headset to suit your style. Enjoy a slow, scenic spectrum cycle or mesmerising colour pulses with preset lighting effects, or customise your own with over 16.8 million colour options to choose from.
Razer Nari Ultimate - headset
Headset - 2.4 GHz - wireless
Headphones Form Factor
Full size
Wireless
Wireless Technology
2.4 GHz radio frequency
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Sound Effects
THX Spatial Audio
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 105 dB
Impedance
32 Ohm
Max Input Power
30 mW
Microphone
Boom
Microphone Operation Mode
Uni-directional
Controls
Mute, volume
Xbox One, Xbox One S, Xbox One X
2 Years
Headband Material
Metal
Earpad Material
Leatherette, memory foam
Max Operating Distance
12 m
Audio Output
Full size
Dynamic
Wireless
Wireless Technology
Sound Output Mode
Stereo
Sound Effects
THX Spatial Audio
Frequency Response
20 - 20000 Hz
Max Input Power
30 mW
Sensitivity
105 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Neodymium
Adjustable Headband
Microphone
Boom
Uni-directional
Sensitivity
-42 dB
Frequency Response
100 - 6500 Hz
Signal-To-Noise Ratio
50 dB
Remote Control
Controls
Mute, volume
Connector Type
Headset (mini-phone 3.5 mm 4-pole)
Rechargeable
2 Years
