Razer Cobra
Quicklinx: HF5MWS00 Mfr#: RZ01-04650100-R3M1
Type: Mouse
£33.33 ex VAT
£39.99 inc VAT
Hit the mark for precision and immersion with the Razer Cobra - a lightweight wired gaming mouse powered by Razer Chroma RGB. Armed with ultra-durable switches and decked out with a gradient Chroma underglow, you'd never expect a mouse so small to pack such big-game performance.
  • Quick swipes and comfortable control
    With a lightweight design that caters to most grip styles, the Razer Cobra not only allows for fast, precise control, but feels extremely comfortable to use even during long hours of gaming.
  • Powered by Razer Chroma RGB
    Customize the Razer Cobra from close to 16.8 million colors and countless lighting effects. Experience greater immersion with an RGB gaming mouse that reacts dynamically with hundreds of Chroma-integrated games.
  • 100% PTFE mouse feet
    Made from the purest, highest grade of PTFE, the Razer Cobra's mouse feet on the front, rear, and sensor ring allows it to glide smoothly across any surface.
Razer Cobra - mouse - lightweight - USB
Mouse
Wired - USB
Orientation
Right-handed
6.25 cm x 11.96 cm x 3.81 cm
58 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
8500 dpi
Performance
90 million clicks, 300 ips tracking speed, 35 G maximum acceleration, 0.2 ms response time
Gaming
6 programmable buttons, polytetrafluoroethylene (PTFE) feet, Chroma lighting system, Razer Speedflex Cable, Razer 3rd-gen optical mouse switch, scrolling wheel, Razer Chroma RGB, on-board memory profile, optical sensor with adjustable DPI, Razer mechanical switches, 1000 Hz polling rate, underglow lighting
Mouse
Orientation
Right-handed
Gaming
6.25 cm
11.96 cm
3.81 cm
58 g
Input Device
Wired
USB
Optical
Buttons Qty
6
Movement Resolution
8500 dpi
Performance
USB cable (type-C to type-A) Speedflex
KCC, EAC, FCC, WEEE, UKCA, BSMI, RCM, CoC
Type: Mouse
Brand: Razer
