The construction of the Razer Kraken had a singular motivation - durability to withstand daily abuse on the go, whether they are tuning out your daily commute or providing the soundtrack while you hit the slopes. Their light-weight design makes these headphones comfortable for hours on end.
The ear cups of the Razer Kraken are foldable, making the footprint of these full-sized headphones extremely compact for maximum mobility so you can take them along anywhere you go.
The Razer Kraken is outfitted with large 40mm neodymium magnet drivers tuned for crystal clear music in the high-and mid-ranges and packing deep bass for powerful lows, making them versatile music and gaming headphones.
Ultra-light comfort
When gaming in the comfort of your own living room, you'll want to feel relaxed so you can game on your console for hours on end. Enjoy the Razer Kraken X. Ultra-light with superior gaming audio. Sit tight and play for hours - your console gaming marathons are about to be a breeze. -
Clear and accurate positional audio
Featuring custom-tuned 40mm drivers, the Razer Kraken X produces clear and balanced sound from thundering explosions in all-out wars to subtle footsteps in stealthy covert operations. -
Ultra-light ergonomic build
Engineered with a lightweight form factor for a near-weightless feel on your head. -
Plush memory foam cushions
Ideal comfort and sound isolation throughout gaming marathons. -
Soft headband padding
Relieves pressure on your head to prevent strain. -
Clamping force
Creates a firm grip on your head to provide a comfortable and measured fit. -
Crystal-clear communication
The flexible and bendable microphone utilizes a cardioid pattern that records sound from an area that focuses on your mouth. This helps to capture your voice with clarity while suppressing background noise from the back and sides. -
Convenient audio control
The microphone mute button and volume slider is easily accessed underneath the left earcup for convenient control.
- Razer Kraken X for PlayStation - headset
- Product Type
- Headset - wired - 3.5 mm jack
- Recommended Use
- Game console
- White
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 12 - 28000 Hz - Sensitivity 109 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Cardioid
- Controls
- Mute, volume control
- 2 Years
- Product Type
- 250 g
- White
- Earpad Material
- Leatherette, memory foam
- Recommended Use
- Game console
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
- 12 - 28000 Hz
- Sensitivity
- 109 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
Microphone
- Boom
- Form Factor
- Headset microphone
- Cardioid
- Sensitivity
- -45 dB
- Sensitivity Margin
- +/- 3dB
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm)
Cable
- Cable Length
- 1.3 m
- Cable Details
- Headset cable - 1.3 m
- 2 Years
