Razer Kiyo
Razer Kiyo
Quicklinx: GCV5WS00 Mfr#: RZ19-02320100-R3M1
Designed and tested by top streamers, the Razer Kiyo is a desktop streaming camera with a powerful, multi-step ring light that you can dim or brighten on command, with the ability to stream at 60 fps for full gaming fidelity. It's the perfect camera for professional streaming.
Spotlight Your Stream
Designed and tested by top streamers, the Razer Kiyo is a desktop streaming camera with a powerful, multi-step ring light that you can dim or brighten on command, with the ability to stream at 60 fps for full gaming fidelity. It’s the perfect camera for professional streaming.
Ring Light, Camera, Action
Forget setting up several lights just to get decent on-camera illumination. The Razer Kiyo maintains even and flattering lighting on you, and eliminates harsh shadows. Plus, with adjustable brightness levels, getting the right amount is a breeze.
Sharper and Smoother
With 720p resolution at 60 fps, the Razer Kiyo maintains visual fidelity when you stream. This means that viewers can be completely immersed the way you are, with footage just the way you see it in-game. Also streams in 1080 resolution at 30fps for Full HD.
Made for Ultimate Compatibility
The Razer Kiyo supports streaming on popular platforms like Open Broadcaster Software and Xsplit, so you can continue using your preferred streaming platform of choice to reach your audiences.
  • Full camera controls
    Enjoy full customization by toggling between auto and manual focus, and adjusting brightness, contrast, saturation and white balance.
  • Ring light
  • Sharper and smoother
    With HD resolution at 60 fps, the Razer Kiyo maintains visual fidelity when you stream. This means that viewers can be completely immersed the way you are, with footage just the way you see it in game.
Razer Kiyo - webcam
Webcam
Audio
Yes: built-in microphone
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate (max)
60 frames per second
Video Modes
480p, 720p, 1080p, 360/30p
Optical Sensor Type
4 MP
Focus Adjustment
Automatic
USB 2.0
USB cable - integrated - 1.5 m
12 white LEDs
1 Year
Webcam
Audio Support
Wired
Camera
Digital Video Format
MJPEG, H.264, YUV2
Max Digital Video Resolution
1920 x 1080
Video Modes
Video Capture
1920 x 1080 @ 30 fps , 1280 x 720 @ 60 fps , 640 x 480 @ 30 fps , 480 x 360 @ 30 fps
Still Image Capture Resolution
2688 x 1520
12 white LEDs
Image Sensor
4 MP
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB 2.0
Ports
USB 2.0
Microsoft Windows 7 or later
System Requirements Details
Windows 7 or later - HD 500 MB
1 Year
