POWER. CLARITY. COMFORT.
Conquer on console and beyond with the Razer Kaira X – a wired Xbox Series X|S headset designed for maximum audio performance and cross-platform compatibility. Armed with cutting-edge drivers and a crystal-clear mic, enjoy competition-ready audio no matter where you game.
RAZER™ TRIFORCE 50MM DRIVERS
The Razer Kaira X features cutting-edge drivers that can tune highs, mids, and lows separately - producing brighter, clearer sound with richer trebles and more powerful bass.
FULLER SOUND
Because the drivers are able to focus on bass, midrange and treble separately, they aren’t restricted to a single range unlike traditional designs. This means the sound qualities of each frequency band is enhanced and doesn’t muddy.
RAZER™ HYPERCLEAR CARDIOID MIC
The bendable mic has improved housing and pickup for amazing voice capture that suppresses noise from the back and sides – supported by mic monitoring and game/chat balance to ensure optimal levels.
ON-HEADSET CONTROLS
Tweak and toggle settings easily with a microphone mute button and volume slider located underneath its left earcup.
CROSS-PLATFORM COMPATIBILITY
Aside from its primary use on Xbox*, the headset’s 3.5mm jack allows it to work with other popular platforms so you can enjoy amazing gaming audio across different setups.
Power, clarity, comfort
Conquer on console and beyond with the Razer Kaira X - a wired Xbox Series X headset designed for maximum audio performance and cross-platform compatibility. Armed with cutting-edge drivers and a crystal-clear mic, enjoy competition-ready audio no matter where you game. -
Razer TriForce 50mm drivers
The Razer Kaira X features cutting-edge drivers that can tune highs, mids, and lows separately - producing brighter, clearer sound with richer trebles and more powerful bass. -
Fuller sound
Because the drivers are able to focus on bass, midrange and treble separately, they aren't restricted to a single range unlike traditional designs. This means the sound qualities of each frequency band is enhanced and doesn't muddy. -
Razer HyperClear cardioid mic
The bendable mic has improved housing and pickup for amazing voice capture that suppresses noise from the back and sides - supported by mic monitoring and game/chat balance to ensure optimal levels. -
FlowKnit memory foam ear cushions
Its breathable weave minimizes sweat and heat build-up, while the ultra-soft foam's improved density greatly reduces the headset's clamping force for snug support during gaming marathons. -
Works with windows sonic
Make the most of the headset's powerful drivers by pairing it with lifelike surround sound that places audio with pinpoint accuracy - heightening your in-game awareness and immersion. -
On-headset controls
Tweak and toggle settings easily with a microphone mute button and volume slider located underneath its left earcup. -
Cross-platform compatibility
Aside from its primary use on Xbox, the headset's 3.5mm jack allows it to work with other popular platforms so you can enjoy amazing gaming audio across different setups.
- Razer Kaira X for Xbox - headset
- Product Type
- Headset - wired - 3.5 mm jack
- Compatibility
- Mac, Windows
- Recommended Use
- Game console, computer
- White
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- Controls
- Volume
- 2-year warranty
- Designed For
- Xbox One, Xbox One S, Xbox One S All-Digital Edition, Xbox One X, Xbox Series S, Xbox Series X
- Product Type
- Compatibility
- Mac, Windows
- 283 g
- White
- Earpad Material
- FlowKnit memory foam
- Recommended Use
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 96 dB
- Impedance
- 32 Ohm
- Diaphragm
- 50 mm
- Magnet Material
- Razer Triforce titanium
Microphone
- Boom
- Form Factor
- Headset microphone
- Uni-directional
- Sensitivity
- -42 dB
- Sensitivity Margin
- +/- 3dB
- 100 - 10000 Hz
Remote Control
- Controls
- Volume
- Connector Type
- Headset (mini-phone 3.5mm)
Cable
- Cable Length
- 1.3 m
- Cable Details
- Headset cable - 1.3 m
- Limited warranty - 2 years
- Designed For
