With over 10 million Razer DeathAdders sold, the most successful gaming mouse of all time sheds its cord for comfort without limits. All hail the Razer DeathAdder V2 Pro - a wireless ergonomic gaming mouse that ushers in a new reign of dominance through total freedom of movement and control.
A proven legacy
While the Razer DeathAdder has evolved over the years, what it's most known for has never changed - amazing ergonomics that have stood the test of time. -
Razer hyperspeed wireless
25% faster than any other wireless technology available, you won't even realize that you're using a wireless gaming mouse due to its high-speed transmission, lowest click latency, and seamless frequency switching in the noisiest, data-saturated environments. -
Razer focus+ optical sensor
The new, improved sensor has an industry-leading 20,000 DPI with 99.6% resolution accuracy, ensuring that even the finest movement from this wireless ergonomic gaming mouse is tracked with consistency. Equipped with intelligent functions, the sensor becomes even more accurate, allowing for an acute level of precision for game-winning headshots. -
2nd Gen Razer optical mouse switch
Improved with greater tactile feedback, every click now feels and sounds more satisfying - actuating via an infrared light beam for an industry-leading response time of 0.2ms. Because this form of actuation no longer requires traditional physical contact, it removes the need for debounce delay and never triggers unintended clicks, giving you closer control and flawless execution.
- Razer DeathAdder V2 Pro - mouse - USB, Bluetooth, 2.4 GHz
- Mouse - ergonomic
- Connectivity Technology
- Wireless, wired - USB, Bluetooth, 2.4 GHz
- Orientation
- Right-handed
- 6.17 cm x 12.7 cm x 4.27 cm
- 88 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 8
- Movement Resolution
- 20000 dpi
- Performance
- 50 G maximum acceleration, 0.2 ms response time, 70 million clicks, 650 inches per second
- Programmable buttons, scrolling wheel, rubber side grips, polytetrafluoroethylene (PTFE) feet, wireless receiver, 5 profiles, Razer Focus+ Optical Sensor, 99% tracking accuracy, Razer Speedflex Cable, Razer Chroma RGB
- 2 Years
- Mouse
- Ergonomic Design
- Orientation
- Right-handed
- 6.17 cm
- 12.7 cm
- 4.27 cm
- 88 g
Input Device
- Wireless, wired
- Interface
- Optical
- Buttons Qty
- 8
- 20000 dpi
- Performance
- 2 Years
