Razer Blackshark V2 Pro - White Edition
Quicklinx: GX1VWS00 Mfr#: RZ04-03220300-R3M1
If competing is your calling, answer it with the Razer BlackShark V2 Pro - the definitive esports gaming headset, unleashed. Powered by Razer HyperSpeed Wireless technology, this triple threat of ultimate mic clarity, audio and sound isolation is the perfect weapon you need to thrive at the highest levels of play.
  • Razer hyperspeed wireless
    With a high-speed transmission and extremely low latency, this wireless esports headset has an industry-leading 2.4GHz wireless connection to ensure lossless audio that'll always stay synced to your game.
  • Razer TriForce titanium 50mm drivers
    The all-new patented design allows engineers to custom tune each driver as though there are three - allowing for the individual replications of high, mid and low audio frequencies to deliver on richer trebles, brighter sound and powerful bass. The Razer BlackShark V2 Pro also includes titanium-coated diaphragms, giving added clarity to any vocals you hear so that any comms you receive is always crisp and clear.
  • Razer hyperclear supercardioid mic
    The pickup pattern on this detachable 9.9mm mic has more noise rejection from the sides as compared to a cardioid mic, and provides a true recreation of your voice thanks to a sensitive low frequency response and an open microphone housing designed for minimal obstruction. Includes Razer Synapse 3 support for access to advanced mic settings.
  • Advanced passive noise cancelation
    From cheering crowds to the hum of your rig, this wireless esports headset shuts out noise using special closed earcups that fully cover your ears, aided by plush cushions that form a perfect seal for greater sound isolation.
  • Flowknit memory foam ear cushions
    The breathable weave minimizes sweat and heat build-up generated by skin contact, while the ultra-soft foam's improved density greatly reduces the headset's clamping force.
  • THX spatial audio
    Increase your immersion and in-game awareness with next-gen surround sound that provides pinpoint positional accuracy and true-to-life acoustics, as you press your advantage with its latest feature: THX Game Profiles. Apply custom-tuned profiles that enhance existing sound design in your favorite games. Choose between THX Environmental Mode for truly lifelike immersion, or THX Competitive Mode for greater spatial awareness.
Razer BlackShark V2 PRO - headset - 3.5 mm jack
Headset - Bluetooth - wireless, wired - 3.5 mm jack
Recommended Use
Portable electronics, computer
White
Headphones Form Factor
Full size
Wireless, wired
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 12 - 28000 Hz - Sensitivity 100 dB
Impedance
32 ohm
Noise Isolating
Microphone
Boom
Microphone Operation Mode
Super cardioid
Controls
Volume, microphone on/mute
16.5 cm
10 cm
20 cm
320 g
White
Earpad Material
Memory foam
Recommended Use
Audio Output
Full size
Headphones Cup Type
Closed
Wireless, wired
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
Frequency Response
12 - 28000 Hz
Sensitivity
100 dB
Impedance
32 ohm
Diaphragm
50 mm
Magnet Material
Razer Triforce titanium
Microphone
Boom
Detachable headset microphone
Super cardioid
Sensitivity
-42 dB
Frequency Response
100 - 10000 Hz
Signal-To-Noise Ratio
60 dB
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm)
Cable
Cable Length
1.3 m
Cable Details
Headset cable - 1.3 m
Headset battery
