Razer Kraken V4
Razer Kraken V4
Quicklinx: HTJMWS00 Mfr#: RZ04-05170100-R3M1
Recommended Use: Game console, Computer
Connectivity: Wireless, Wired
22 In Stock
£146.33 ex VAT
£175.59 inc VAT
The construction of the Razer Kraken had a singular motivation - durability to withstand daily abuse on the go, whether they are tuning out your daily commute or providing the soundtrack while you hit the slopes. Their light-weight design makes these headphones comfortable for hours on end.
The ear cups of the Razer Kraken are foldable, making the footprint of these full-sized headphones extremely compact for maximum mobility so you can take them along anywhere you go.
The Razer Kraken is outfitted with large 40mm neodymium magnet drivers tuned for crystal clear music in the high-and mid-ranges and packing deep bass for powerful lows, making them versatile music and gaming headphones.
  • Designed for maximum comfort and durability
  • Foldable ear cups for maximum portability
  • Large 40mm Neodymium drivers for powerful audio
Razer Kraken V4 - headset
Headset - Bluetooth / 2.4 GHz radio frequency - wireless, wired - USB-A, USB-C
Compatibility
Windows, Mac
Recommended Use
Computer, Game console
Gaming
Headphones Form Factor
Full size
Wireless, wired
Wireless Technology
Bluetooth Version
Bluetooth 5.3
Sound Effects
THX Spatial Audio
Audio Specifications
Frequency Response 20 - 28000 Hz - Sensitivity 98 dB/mW
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional (HyperClear super wideband)
Controls
Razer SmartSwitch button, game/chat balance, microphone on/mute
Compatibility
Windows, Mac
Dimensions & Weight Details
Inner earcup diameter: 4.5 cm x 6.2 cm
350 g
Earpad Material
Memory foam, breathable fabric
Recommended Use
Gaming
Audio Output
Full size
Wireless, wired
Wireless Technology
Bluetooth Audio Codec
AAC, SBC
Bluetooth Version
Bluetooth 5.3
Sound Effects
THX Spatial Audio
Frequency Response
20 - 28000 Hz
Sensitivity
98 dB/mW
Impedance
32 Ohm
Diaphragm
40 mm
Magnet Material
Razer Triforce titanium
Razer Chroma RGB, 9 zone earcup lighting
Microphone
Boom
Headset microphone
Sensitivity
-42 dBV/Pascal
Sensitivity Margin
+/- 3dB
Frequency Response
100 - 10000 Hz
Retractable microphone
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
USB-C dongle
Supported Host Device OS
iOS, Android, Windows, macOS
Handset battery rechargeable
Run Time (Up To)
70 hour(s)
Run Time Details
Continuous playback (2.4 GHz / lighting OFF): up to 70 hours , Continuous playback (2.4 GHz / lighting ON): up to 35 hours
Recommended Use: Computer
Connectivity: Wired
Brand: Razer
