AegisSAN V100 is the SAN storage series designed for surveillance and backup applications to deliver ultra performance.
Video surveillance
The series supports up to 200 IP cameras and offers easy-to-use management tools to do central management for all the storage systems. AegisSAN V100 disk array provides great scalability supporting up to 192 hard drives and its enterprise-grade performance enables the system to handle the surveillance workload satisfactorily. -
Hardware offload engine
AegisSAN V100 system features hardware offload engine, the proprietary QiSOE technology, which adopts a dedicated CPU core to process the packets. With hardware offload engine enabled, the read/write throughput can be dramatically boosted as well as IOPS performance. -
Data protection
AegisSAN V100 disk array provides comprehensive enterprise-grade data protection features. It has multiple RAID level options, QSnap the writable snapshot function, volume cloning, online disk roaming and instant volume restoration to protect the all stored data.
- Qsan AegisSAN V100-P10 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 3U
- Interface
- iSCSI (1 GbE)
- Host Channels
- 6
- Maximum LUNs
- 2048
- Installed Devices / Modules Qty
- 0 (installed) / 16 (max)
- Supported Drives
- SATA-600 / SAS-2
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Storage Controller Quantity
- 1
- Hard Drive
- No HDD
- Power
- AC 120/230 V
- Power Redundancy
- 44.6 cm x 54.97 cm x 13 cm
- 30 kg
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- 0
- Supported Devices / Modules Qty
- 16
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
- iSCSI (1 GbE)
- Host Channels
- 6
- Maximum LUNs
- 2048
RAM
- Installed Size
- 4 GB
Storage Controller
- RAID
- Installed Qty
- 1
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Storage Controller (2nd)
- Installed Qty
- 1
Hard Drive
- No HDD
- Expansion Bays
- 16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
- 6 x Ethernet 1000 , 1 x management
- Built-in 3 cooling fans
- C-Tick, BSMI, CB, FCC, RoHS, LVD
- Power Device
- 2 x internal power supply
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- AC 120/230 V
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Power Factor Correction
- 44.6 cm
- 54.97 cm
- 13 cm
- 30 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
