The premier storage choice for creative audio/video professionals and multimedia enthusiasts around the globe, the Promis Pegasus2 can now deliver even faster performance with the 20 Gb/s Thunderbolt 2 technology, while assuring enterprise-class reliability and ease of use.
Incredible speed for creative workflows
The Pegasus2 is the fastest Thunderbolt 2 storage solution available, delivering raw power for audio/video/graphics amateurs and professionals alike to experience new capabilities with ease. Final Cut professionals can ingest, edit and play back multiple streams of ProRes 422 (HQ), ProRes 4444 as well as uncompressed HD 10-bit and 12-bit video, while protecting valuable workflows, audio sessions and other creative media content. -
Simple, flexible and cost-effective backup solution for SOHO
Fast, safe and reliable external storage is essential when protecting your valuable files such as music, photos and videos. The hardware RAID capabilities of the Pegasus2 family protects all the memories that were meant to last a lifetime that could be impacted from single drive failures, while simultaneously providing data protection and high reliability. The Pegasus2 family provides fast performance for popular applications such as iTunes, iPhoto, iMovie, GarageBand, Photoshop and media center applications. Back up your irreplaceable digital media, documents, and also your entire computer or workstation to Pegasus2 with Time Machine in OS X. -
Easy to use, quiet and eco-smart
Pegasus2 systems are user friendly and come preconfigured straight out of the box - so you can just plug in and start using. Status, management tools and advanced settings can be accessed via the built-in Promise Utility. Engineered to be eco friendly and RoHS compliant, Pegasus2 is perfect for SOHO and SMB environments. -
Enterprise-class RAID protection
Pegasus2 features enterprise-level RAID storage protection for your data, supporting a broad range of RAID levels as well as automatic error handling.
- Promise Pegasus2 R6 - hard drive array
- Hard drive array
- Total Array Capacity
- 18 TB
- Max Supported Capacity
- 18 TB
- Interface
- Thunderbolt 2
- Installed Devices / Modules Qty
- 6 (installed) / 6 (max)
- Supported Drives
- SATA-600
- Storage Controller
- RAID (SATA 6Gb/s) - RAID RAID 0, 1, 5, 6, 10, 50
- Hard Drive
- 6 x 3 TB HDD - hot-swap
- OS Required
- Apple OS X 10.8.5 Mountain Lion or later
- 18.7 cm x 25 cm x 25.1 cm
- 8.9 kg
- 2-year warranty
- Hard drive array
Chassis
- 6
- Supported Devices / Modules Qty
- 6
- Supported Drives
- SATA-600
Storage
- 18 TB
- 18 TB
- HDD Array External Interface
- Thunderbolt 2
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50
Hard Drive
- HDD - hot-swap
- Capacity
- 6 x 3 TB
- Spindle Speed
- 7200 rpm
- Expansion Bays
- 6 (total) / 0 (free) x hot-swap - 3.5"
- 2 x Thunderbolt 2
- OS Required
- Cables Included
- 1 x Thunderbolt cable
- Power Device
- Internal power supply
- 18.7 cm
- 25 cm
- 25.1 cm
- 8.9 kg
- Limited warranty - 2 years
