ProLabs 1000BASE-SX SFP 850nm 550m over MMF
Quicklinx: F2RQWS00 Mfr#: MA-SFP-1GB-SX-C
Marketing description is not available.
ProLabs MA-SFP-1GB-SX-C - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
Meraki MA-SFP-1GB-SX
4.5 cm x 2 cm x 11.5 cm
31 g
Plug-in module
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
550 m
1 x Ethernet 1000Base-SX - LC multi-mode x 2
4.5 cm
2 cm
11.5 cm
31 g
