Polycom CX100 Speakerphone gives you the ultimate hands-free calling experience from your Microsoft Office Communicator 2007-enabled computer. Polycom CX100 Speakerphone enables crystal-clear, natural conversations without echoes or feedback. Enjoy the freedom of not wearing your headset for hands-free calls, or plug into the built-in stereo headphone port for private conversations.
Polycom CX100 Speakerphone delivers remarkable wideband audio quality that enables seamless voice and video communications with no compromises. Two high-quality microphones provide excellent range for small group conversations.
Polycom CX100 Speakerphone connects and powers through an integrated USB cable for easy installation and use - no extra cables to carry or batteries to charge. Its small size and carrying case make it easy to take with you. Plus, the high-fidelity speaker doubles as a great portable solution for CD-quality music and presentation audio.
- Poly CX100 Speakerphone - VoIP desktop speakerphone
- Product Type
- VoIP desktop speakerphone - wired
- Charcoal grey
- Connectivity Technology
- Wired
- Audio Specifications
- Frequency Response 300 - 19000 Hz
- Microphone
- Built-in
- Microphone Operation Mode
- Mono
- Microphones Included
- 2
- Controls
- Mute, volume, answer/end
- 1-year warranty
- Product Type
- 8.2 cm
- 2.2 cm
- 13.3 cm
- 151 g
- Charcoal grey
Audio Output
- Wired
- 300 - 19000 Hz
Microphone
- Mono
- 2
- 200 - 20000 Hz
- Audio Input Details
- Cardioid - 200 - 20000 Hz
Remote Control
- Controls
- Connector Type
- USB , Headphones (mini-phone 3.5mm)
- Included Accessories
- Carrying case
- Cable Details
- USB cable
- VCCI, C-Tick, GOST, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, CB, CCC, FCC Part 15, MIC
- Limited warranty - 1 year
