Poly Voyager Focus 2 UC-M C USB-C WW
Quicklinx: HM5QWS00 Mfr#: 77Y88AA
Recommended Use: Portable electronics, Computer
Connectivity: Wired, Wireless
Earcover : Binaural
£85.28 ex VAT
£102.33 inc VAT
Create a focus zone around you with the Voyager Focus 2, stereo Bluetooth headset. Smartly engineered for audio perfection – all you will hear is your call. And the focus stays on you, right where it belongs.
  • Immersive experience
    Stay focused while on calls or listening to music/media with stereo sound.
  • Easy to use
    An easy-to-use headset with smart sensors for answering/muting calls and playing/pausing music. The intelligent microphone boom automatically maintains left and right audio no matter which side the headset is worn on.
  • It's your call
    Stay productive with up to 19 hours of wireless talk time (ANC on) and extend the battery life by using it corded, with audio over USB mode.
  • Choose your device
    Works with your choice of device: PC via included BT700 USB-A or USB Type-C ? Bluetooth adapter and mobile phones via Bluetooth v5.1.
  • Smart sensors
    Dynamic Mute Alert senses and tells you when talking while muted. And the on-ear indicator light flashes to let others around you know you are on a call to keep you distraction free.
  • Certified for Microsoft Teams
    Full Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
Poly Voyager Focus 2-M - headset - USB-C
Headset - Bluetooth - wireless, wired - USB-C
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Active Noise Canceling
Microphone
Boom
Microphone Operation Mode
MEMS-directional
Microphones Included
4
Controls
Mute, volume, power on/off, answer/end, ANC mode
Software Certification
15.5 cm
6.7 cm
18.2 cm
176 g
Earpad Material
Artificial leather
Recommended Use
Max Operating Distance
50 m
Audio Output
On-ear
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Stereo
Active Noise Cancelling Technology
Hybrid Active Noise Cancelling
Frequency Response
20 - 20000 Hz
Diaphragm
32 mm
Adjustable Headband
Simultaneously Connectable Devices Qty
2
Dynamic EQ optimised
Microphone
Boom
MEMS-directional
4
Frequency Response
100 - 6800 Hz
Remote Control
Controls
Connector Type
USB (USB Type-C)
Charging cable, BT700 Bluetooth USB-C adapter, travel pouch
Cable Details
Micro-USB charging cable
Supported Host Device OS
Windows 11, Windows 10, macOS
Headset battery rechargeable - Lithium Ion
560 mAh
Run Time (Up To)
40 hours
Run Time Details
Continuous talk (noise cancelling ON): up to 16 hours , Continuous talk (noise cancelling OFF): up to 18 hours , Continuous hearing (noise cancelling ON): up to 24 hours , Continuous hearing (noise cancelling OFF): up to 40 hours
Standby Time
30 days
Recharge Time
2 hours
Shipping Width
21 cm
Shipping Depth
19 cm
Shipping Height
11.5 cm
Shipping Weight
712 g
HM5Q Poly Spare BT700 Bluetooth USB Adapter In Stock £58.36
HM5Q Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager In Stock £87.61
HM5Q Poly - USB adapter - USB to 24 pin USB-C In Stock £12.86
HM5Q Poly - USB adapter - 24 pin USB-C to USB In Stock £12.95
Recommended Use: Computer
Connectivity: Wired
Connectivity: Wireless
Earcover : Binaural
Brand: Poly
