Power up productivity for office workers with the Voyager 4200 UC Series Bluetooth wireless headsets. Connecting is seamless - smartphone or computer. Outstanding audio, freedom to roam.
                Escape the deskGive office workers flexibility and hands-free productivity with up to 30 meters / 98 feet of Bluetooth wireless range with the included BT600 USB adapter.
                Connectivity optionsEasy connectivity options for your different communication needs: BT600 USB Bluetooth adapter to connect to your PC and directly to the mobile phone via Bluetooth .
                No need for battery anxietyKeep your headset fully charged using a desktop charging stand. You can also extend the battery life by using it corded, with audio over USB mode.
                Smart sensorsDynamic Mute Alert senses and tells you when talking while muted. And the on-ear indicator light flashes to let others around you know you are on a call to keep you distraction free.
                Easy management via Poly LensTake control of your deployment from anywhere via remote management with Poly Lens cloud-based device management software.
                Certified for Microsoft TeamsFull Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
- Poly - for Microsoft Teams - wireless headset system base for Bluetooth headset
- Product Type
- Wireless headset system base
- Intended For
- Bluetooth headset
- Package Content
- Wireless headset system base, USB cable, telephone interface cable, power adapter
- Compatible Software
- Microsoft Teams
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Designed For
- Poly Voyager 4320; Voyager 4300 UC Series 4310; Voyager Focus 2 Office; 2 UC
- Product Type
- Intended For
- Bluetooth headset
- Microsoft Teams
- Package Content
- Limited warranty - 2 years
- Designed For
- Poly Voyager 4320 , Poly Voyager 4300 UC Series 4310 , Poly Voyager Focus 2 Office , Poly Voyager Focus 2 UC
