Poly SYNC 20 SY20 USB C WW
Quicklinx: G1D2WS00 Mfr#: 216868-01
Let's face it: the audio on your laptop and smartphone aren't great. Sound like the professional you are with Poly Sync 20 USB/Bluetooth smart speakerphone-for remarkable conference calls and music anywhere. Take it wherever you go-its battery lasts for hours. You'll always hear and be heard.
Poly Sync 20 - smart speakerphone
Smart speakerphone - Bluetooth - wireless, wired - USB-C
Compatibility
Mac, Windows
Recommended Use
Portable electronics
Additional Functions
USB charging port
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Audio Specifications
Frequency Response 80 - 20000 Hz
Microphones Included
3
Controls
Mute, volume, power on/off, answer/end, pair mode
Compatibility
Mac, Windows
USB charging port
18.2 cm
9.5 cm
3.4 cm
350 g
Recommended Use
Kensington lock secure slot, touch control, noise reduction
Protection
Dust-resistant, water-resistant, IP64
Audio Output
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Frequency Response
80 - 20000 Hz
Diaphragm
40 mm
Acoustic echo cancelation
Microphone
Built-in
3
Frequency Response
100 - 6700 Hz
Remote Control
Controls
Connector Type
USB (USB Type-C) , USB (power only) (4 pin USB Type A (power only))
Carrying case, lanyard
Cable Details
USB-C cable - 71 cm
IP64
Speaker phone battery rechargeable - Lithium Ion
3200 mAh
Run Time (Up To)
20 hour(s)
Recharge Time
4 hour(s)
