Polycom STUDIO X50 and TC8
Quicklinx: FN8HWS00 Mfr#: 2200-86270-102
Poly Studio X50 Video Bar delivers radical simplicity in a small and elegant package. Now you can huddle happy in smaller rooms and connect easy in conference rooms whatever video collaboration software you use. Experience full board-room quality audio, advanced camera capabilities, and wireless content sharing that you can fling your content onto in seconds, all miniaturized into one sleek bar. So, say good bye to pucks, cords, and cables. Ditch the PC to drive the meeting, since the Poly Video OS runs the show. Easy to install, easy to manage - and best of all, easy to use.
Poly Studio X50 - video conferencing kit - with Poly TC8
Video conferencing kit
Kit Content
Touchscreen console, video bar
VoIP Protocols
H.323, SIP
Codec
H.264, H.265, H.239, H.264 High Profile, G.711, G.722, G.728, G.729a, G.722.1, G.722.1c, AAC-LD, G.719
United Kingdom
Video Input
Digital camera
Video Output
3840 x 2160
Audio Input
Three microphones
Audio Output
Speaker(s) - stereo
Input Device
8" touchscreen (wired)
Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Software Certification
Zoom Certified
1-year warranty
Bundled with
Poly TC8
Kit Content
VoIP Protocols
H.323, SIP
Voice Codecs
Video Codecs
Security
128 bit AES, 256 bit AES, TLS 1.0, TLS 1.1, TLS 1.2, H.235.6, FIPS 140-2
Dimensions & Weight Details
Touch screen - Width 20.5 cm Depth 7.9 cm Height 12.3 cm Weight 812 g , Video bar - Width 76.2 cm Depth 10.2 cm Height 10.2 cm Weight 2.54 kg
Built-in Devices
Stereo speakers, camera, 3 microphones
United Kingdom
Bundled with
Poly TC8
Video Input
Digital camera - integrated
Video Modes
2160p
Optical Zoom
5
ePTZ, auto tracking, auto-framing, 120° field of view, 2 preset positions, Miracast connectivity
Video Output
Max External Resolution
3840 x 2160
Supported Display Graphics
XGA (1024x768), SXGA (1280x1024), SXGA+ (1400x1050), HDTV (1920x1080), WUXGA (1920 x 1200), HD (1280 x 720), WSXGA+ (1680 x 1050), 352x240, 176x144, UHD (3840 x 2160)
Analogue Video Signal
(NTSC, PAL)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Audio Input
Three microphones - integrated
Audio Output
Speaker(s)
Sound Output Mode
Stereo
Input Device
8" touchscreen
Wired
Network adapter
Wireless, wired
OCSP support, auto-uplink (auto MDI/MDI-X), IPv6 support, MIMO technology, IPv4 support, Apple AirPlay, Polycom Lost Packet Recovery (LPR) technology, Simple Certificate Enrollment Protocol (SCEP)
1 x audio / video - HDMI input - 19 pin HDMI Type A , 2 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 , 1 x USB-C - 24 pin USB-C , 1 x audio - line-In - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x network cable - 4.57 m , 1 x HDMI cable - 1.83 m
Wall mount, cables
Zoom Certified
FIPS 140-2
Limited warranty - parts and labour - 1 year
15 - 80% (non-condensing)
