Poly SYNC 20+ SY20 M USB C BT600C WW
Quicklinx: G1D5WS00 Mfr#: 216871-01
Let's face it: the audio on your laptop and smartphone aren't great. Sound like the professional you are with Poly Sync 20 USB/Bluetooth smart speakerphone-for remarkable conference calls and music anywhere. Take it wherever you go-its battery lasts for hours. You'll always hear and be heard.
Poly Sync 20+ for Microsoft Teams (with Poly BT600C) - smart speakerphone - USB-C, USB-C via Bluetooth adapter
Smart speakerphone - Bluetooth - wired, wireless - USB-C, USB-C via Bluetooth adapter
Compatibility
Mac, Windows
Recommended Use
Portable electronics
Additional Functions
USB charging port
Wired, wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Audio Specifications
Frequency Response 80 - 20000 Hz
Microphones Included
3
Controls
Answer/end, mute, volume, power on/off, pair mode, Microsoft Teams button
Compatibility
Mac, Windows
USB charging port
18.2 cm
9.5 cm
3.4 cm
350 g
Recommended Use
Noise reduction, touch control, Kensington lock secure slot
Protection
IP64, dust-resistant, water-resistant
Audio Output
Wired, wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Frequency Response
80 - 20000 Hz
Diaphragm
40 mm
Acoustic echo cancelation
Microphone
Built-in
3
Frequency Response
100 - 6700 Hz
Remote Control
Controls
Connector Type
USB (USB Type-C) , USB (power only) (4 pin USB Type A (power only))
Carrying case, lanyard, Bluetooth USB-C adapter
Cable Details
USB-C cable - 71 cm
IP64
Speaker phone battery rechargeable - Lithium Ion
3200 mAh
Run Time (Up To)
20 hour(s)
Recharge Time
4 hour(s)
