This intuitive touch interface provides easy access to Poly video conferencing solutions. The sleek design features an 8" high-resolution touch display to ensure that the control options are clear and accessible. A single cable carries both power and data to reduce clutter. After using the Poly TC8, you’ll never stress about getting your meeting going again. Having confidence that you can easily initiate, join, or share content lets you focus on better collaboration.
- Integrated calendar for one touch to join a call
- Easily share content, adjust the camera, and change participant layouts
- Compatible with Poly Studio X family and Poly G7500
- Poly TC8 - video conferencing device
- Video conferencing device
- 20.5 cm x 7.9 cm x 12.3 cm
- 812 g
- Display
- 8" IPS / 1280 x 800
- Networking
- Network adapter
- 1-year warranty
- 20.5 cm
- 7.9 cm
- 12.3 cm
- 812 g
Display
- Technology
- IPS
- Diagonal Size
- 8"
- Native Resolution
- 1280 x 800
- Image Aspect Ratio
- 16:10
- Monitor Features
- LED-backlit, capacitive touch screen
- Network adapter
- Connectivity Technology
- Wired
- PoE powered, security slot (Kensington security lock compatible)
- IEEE 802.3af
- 1 x USB 2.0 - Micro-USB Type B , 1 x network / power - RJ-45
- Limited warranty - 1 year , Software application support - 90 days
- 0 °C
- 40 °C
