Enjoy simply better conversations with the Savi 8200 Series. Effortlessly manage PC, mobile and desk phone calls, with enterprise-grade DECT audio.
One headset for all your devices
Today's enterprise and contact center professionals work across a range of devices - from PC to mobile to desk phone. The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 Series headsets for training or call resolution. -
Connect and communicate more effectively
The Savi 8200 Series headset system helps you achieve peak performance and productivity with a range of communication features. Enterprise-grade DECT audio allows you to roam or multi-task up to 590 ft/180 m from your PC. One-touch controls - such as call answer/end, volume up/down and mute - let you manage calls from any connected device within roaming range. Convenient voice prompts notify you of mute status, roaming range limit, and more.
- Poly Savi 8200 Series W8210/A - headset
- Product Type
- Headset - DECT / Bluetooth - wireless
- Recommended Use
- Phone, computer
- Localisation
- EMEA
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT / Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 118 dB
- Impedance
- 32 Ohm
- Active Noise Canceling
- Microphone
- Boom
- Controls
- Mute, volume, on/off, answer/end
- Product Type
- 115 g
- Recommended Use
- Phone, computer
- Max Operating Distance
- 180 m
- Localisation
- EMEA
Audio Output
- On-ear
- Wireless
- DECT / Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Mono
- 20 - 20000 Hz
- Sensitivity
- 118 dB
- Impedance
- 32 Ohm
- Diaphragm
- 32 mm
Microphone
- Boom
- 100 - 6800 Hz
- Max Sound Pressure
- 112 dB
Remote Control
- Controls
- Included Accessories
- Base station, charging cradle, power supply unit
- Cable Details
- USB cable , Phone cable , USB-C cable
- Battery
- Headset battery rechargeable - lithium polymer
- Capacity
- 490 mAh
- Run Time (Up To)
- 13 hour(s)
- Standby Time
- 50 hours
- Recharge Time
- 3 hour(s)
