Poly 4 Voyager Focus UC B825- M Headset - No Stand
Quicklinx: HM5FWS00 Mfr#: 7F0J2AA
Recommended Use: Computer, Portable electronics
Connectivity: Wireless
Earcover : Binaural
Hurry, only 1 left in stock!
£171.80 ex VAT
£206.16 inc VAT
Make it your business to hear and be heard with the Voyager Focus UC stereo Bluetooth headset. Move fluidly between PC and smartphone and between work and entertainment with rich, immersive stereo sound and active noise canceling designed to keep your focus on work, not on the chaos around you.
  • Connect with ease
    Premium wireless stereo headset works seamlessly across multiple applications on desktops, Bluetooth -enabled desk phones, laptops, mobile phones and tablets.
  • Smart sensor technology
    Smart sensors know when the headset is on or off; calls can be easily answered by simply putting on the headset; pause music for incoming calls, or mute a call by taking the headset off.
  • Focus on work–not the chaos around you
    Shut the world out with on-demand active noise cancelation (ANC) that reduces distracting background sound in noisy environments so you can focus on your call or work.
  • Outstanding audio quality
    With three precisely tuned microphones and enhanced noise cancelling, optimize your voice and minimize noise caused by wind, movement, and background sounds so your caller hears you, not your surroundings.
  • Worry-free mute assurance
    Dedicated mute button gives you quick mute access while voice alert announces mute on/off status. Dynamic mute alert notifies you when you try to talk when muted, for worry-free mute assurance.
  • Premium audio experience
    High-quality, dual-ear design provides hi-fi stereo sound and a more immersive experience to enable focus in open work environments.
Poly Voyager Focus B825-M - headset
Headset - Bluetooth - wireless - USB-A via Bluetooth adapter
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Microphone Operation Mode
MEMS-directional
Microphones Included
3
Controls
Volume, answer/end, microphone on/mute, play/pause
Software Certification
Certified for Skype for Business, Certified for Microsoft Teams
18.3 cm
16 cm
7 cm
155 g
Recommended Use
Max Operating Distance
30 m
Audio Output
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Diaphragm
32 mm
Simultaneously Connectable Devices Qty
8
Smart Sensor Technology
Microphone
Boom
MEMS-directional
3
Frequency Response
100 - 6700 Hz
Remote Control
Controls
Travel pouch, BT700 Bluetooth USB adapter
Cable Details
Micro-USB charging cable
Headset battery rechargeable
325 mAh
Run Time (Up To)
15 hour(s)
Run Time Details
Continuous playback (AAC, active noise-cancelling on): up to 12 hours , Continuous talk (active noise-cancelling off): up to 12 hours , Continuous talk (active noise-cancelling on): up to 10 hours , Continuous playback (active noise-cancelling off): up to 15 hours
Recharge Time
2 hour(s)
Shipping Width
18.6 cm
Shipping Depth
21 cm
Shipping Height
11.6 cm
Shipping Weight
678.7 g
Recommended Use: Portable electronics
Earcover : Binaural
Brand: Poly
