Poly Headset Splitter - Y-Type Training Cable
Quicklinx: HLHYWS00 Mfr#: 85S09AA
18 In Stock
£22.24 ex VAT
£26.68 inc VAT
Express delivery Order within the next 20 hours for delivery on Wednesday
The Poly Y-Training Cable (6-pin) part # Poly 79694-11 or HP 85S09AA allows two headsets to operate with one amplifier for training/monitoring purposes. Both headsets can listen, but only one headset will have a live microphone. The other microphone is muted. The red toggle switch allows the supervisor to control which microphone is live and which is muted. This cable is TAA Compliant.
  • Efficient collaboration
    The Y-type training cable design allows for simultaneous audio input, making it an ideal solution for collaborative environments where sharing audio sources is essential.
  • Versatile connectivity
    Designed as a headset splitter, this cable offers versatile connectivity options, enabling users to connect multiple headsets to a single audio source without compromising sound quality.
Poly headset splitter
Cable
Headset splitter
Cable Type
Headset splitter Y-type training cable
Quick disconnect lock
Shipping Width
13 cm
Shipping Depth
21 cm
Shipping Height
7 cm
Shipping Weight
110 g
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HLHY 051025
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £18.08
Ref: HLHY 049004
Condition: Damaged stock - Item is new but has packaging damage
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £3.12
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Poly
Stock Status: Used Stock
