Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
High-quality audio
Makes collaboration easy with Poly signature audio quality and reliability. -
Wearing style
Monaural wearing style for those who prefer to leave one ear open. -
Headset flexibility
With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom. -
Long-lasting comfort
Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions. -
Connectivity options
Enhanced connectivity for your devices: USB Type-C cord with tethered USB-A adapter for PC and 3.5 mm for mobile or tablet connectivity. -
Optimized for communications platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
- Poly Blackwire 3315 - headset - 3.5 mm jack, USB-C
- Product Type
- Headset - wired - 3.5 mm jack, USB-C
- Compatibility
- Mac, Windows
- Recommended Use
- Computer, portable electronics
- Black
- Headphones Form Factor
- On-ear monaural
- Connectivity Technology
- Wired
- Audio Specifications
- Sensitivity 116 dB
- Impedance
- 32 Ohm
- Signal-To-Noise Ratio
- 118 dB
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Microphone Noise Cancelling
- Controls
- Answer/end, mute, volume
- Software Certification
- UC certified
- Product Type
- Series
- Blackwire 3300 series
- Compatibility
- Mac, Windows
- 103 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- 280° rotatable microphone, boom mic length 135mm
Audio Output
- On-ear monaural
- Wired
- 118 dB
- Sensitivity
- 116 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 118 dB
- Diaphragm
- 14.2 mm
- In-Cord Volume Control
- Dynamic EQ optimised, echo reduction
Microphone
- Boom
- Omni-directional
- Sensitivity
- -38 dBV/Pascal
- Sensitivity Margin
- +/- 3dB
- Frequency Response
- 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
- Included Accessories
- USB-C to USB-A adapter
- Supported Host Device OS
- Windows 10, macOS
- UC certified
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £13.08 |
Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £9.00 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £13.30 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £13.36 |
Poly Spare Foam Ear Cushion BW3310 BW3320 | In Stock | £2.76 |
