Poly Calisto 5300 CL5300-M USB-A/BT600
Quicklinx: G1BTWS00 Mfr#: 215438-01
Sound better wherever you're working - at home, remote or in the office. With Calisto 5300, professional audio quality goes wireless.
  • Rich, clear audio anywhere
    Hear and be heard, even when you're working from a remote location. The full-duplex 360° microphone makes your voice clear. With its amplified speaker and wide frequency response, it's even great for multimedia.
  • Bluetooth connectivity
    Built-in Bluetooth and USB connectivity lets you connect to all your devices.
  • Superior audio quality
    Enjoy full-duplex audio with 360° room coverage for easy, natural conversation.
  • Dynamic mute alert
    Dynamic mute alert senses and alerts you if you talk while muted.
  • Compact and portable
    A soft carrying case is included for easy storage and portability.
  • Like a mobile conference room
    You'll love how easy it is to pack up and set up - Calisto 5300 has an integrated cable management system and a convenient carrying case.
Poly Calisto 5300 - Microsoft - speakerphone
Speakerphone - Bluetooth - wireless
Recommended Use
Portable electronics, computer, conference - communication
Wireless
Wireless Technology
Bluetooth
Audio Specifications
Frequency Response 150 - 20000 Hz - Sensitivity 81.5 dB/Watt
Impedance
4 Ohm
Microphone Technology
Condenser
Microphone Operation Mode
Omni-directional
Controls
Mute, volume control, on/off, answer/end, Microsoft Teams button
10.86 cm
10.86 cm
3.11 cm
214 g
Recommended Use
Voice alerts
Audio Output
Wireless
Wireless Technology
Bluetooth
Frequency Response
150 - 20000 Hz
Sensitivity
81.5 dB/Watt
Impedance
4 Ohm
Microphone
Built-in
Condenser
Omni-directional
Directivity Angle
360°
Frequency Response
100 - 7500 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Carrying case, Bluetooth USB adapter
Cable Details
USB cable
Speaker phone battery lithium polymer
1000 mAh
Run Time (Up To)
16 hour(s)
Recharge Time
3.5 hour(s)
