Brand
Poly Calisto 5300 CL5300-M USB-A
Quicklinx: G1BRWS00 Mfr#: 215436-01
£73.44 ex VAT
£88.12 inc VAT
Sound better wherever you're working - at home, remote or in the office. With Calisto 5300, professional audio quality goes wireless.
  • Rich, clear audio anywhere
    Hear and be heard, even when you're working from a remote location. The full-duplex 360° microphone makes your voice clear. With its amplified speaker and wide frequency response, it's even great for multimedia.
  • Bluetooth connectivity
    Built-in Bluetooth and USB connectivity lets you connect to all your devices.
  • Superior audio quality
    Enjoy full-duplex audio with 360° room coverage for easy, natural conversation.
  • Dynamic mute alert
    Dynamic mute alert senses and alerts you if you talk while muted.
  • Compact and portable
    A soft carrying case is included for easy storage and portability.
  • Like a mobile conference room
    You'll love how easy it is to pack up and set up - Calisto 5300 has an integrated cable management system and a convenient carrying case.
Poly Calisto 5300 - Microsoft - speakerphone
Speakerphone - wired - USB
Recommended Use
Portable electronics, computer, conference - communication
Wired
Audio Specifications
Frequency Response 150 - 20000 Hz - Sensitivity 81.5 dB/Watt
Impedance
4 Ohm
Microphone Operation Mode
Omni-directional
Controls
Mute, volume control, on/off, answer/end, Microsoft Teams button
Software Certification
Certified for Microsoft Teams
3.11 cm
Diameter
10.86 cm
Recommended Use
Voice alerts
Audio Output
Wired
Frequency Response
150 - 20000 Hz
Sensitivity
81.5 dB/Watt
Impedance
4 Ohm
Microphone
Built-in
Omni-directional
Directivity Angle
360°
Sensitivity
-26 dB
Frequency Response
100 - 7500 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Carrying case
Cable Details
USB cable
Speaker phone battery rechargeable - lithium polymer
1000 mAh
Run Time (Up To)
16 hour(s)
Recharge Time
3.5 hour(s)
Brand: Poly
