The Polaroid P3 is already an icon. This is THE design piece to own in the series of Polaroid players. The P3 is truly an object to display, not hide.
The Polaroid P3 Player has some real presence. Coming in around the dimensions of a pineapple (including the ‘crown’, which turns out to be the proper name of that top bit), it’s the choice to make for when more volume is needed. Plus, it’s still a portable speaker, thanks to its polished metal handle. And while none of the Polaroid Players are designed to blend in, the Polaroid P3 speaker is a true stand-out, bringing back big boombox energy with its retro-futuristic vibes. The Polaroid P3 also features the full functionality of the Polaroid Music App, meaning you can easily set up your favorite music channels and scroll through them with the analog dial.
Output power 35 W
The most iconic music player. -
Stereo pairing
Connect another P3 for stereo sound. -
Rechargeable battery
Provides up to 15 hours of playback time.
- Polaroid P3 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Frequency Response
- 100 - 20000 Hz
- Amplifier
- Integrated
- NFC, Bluetooth
- Red
- Battery
- Speaker battery rechargeable
- 30 cm x 7 cm x 14 cm
- 1.485 kg
- 1-year warranty
- Product Type
- Qualcomm TrueWireless Stereo (TWS), stereo pairing
- Enclosure Colour
- Red
- Enclosure Material
- Nylon, polyester, iron, PP/PC, acrylonitrile butadiene styrene (ABS), thermoplastic polyurethane (TPU)
Speaker System
- Speaker Type
- Active
- 100 - 20000 Hz
- Sensitivity
- 75 dB
- Amplifier
- Integrated
- Near Field Communication (NFC), Bluetooth 5.0
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Controls
- Volume, play/pause, next track, previous track, activate Bluetooth
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- USB-C charging cable
- Power Source
- Battery
- Rechargeable
- Capacity (Ah)
- 4000 mAh
- Voltage Provided
- 7.2 V
- Run Time (Up To)
- 15 hour(s)
- 30 cm
- 7 cm
- 14 cm
- 1.485 kg
- Limited warranty - 1 year
