The Polaroid P2 is a small but mighty Bluetooth speaker that doubles as a fashion accessory.
The player comes with a wrist strap that makes it super easy (and kinda cool) to carry around and the design is tactile, made to be held and felt. The P2 player is more than twice as powerful as the P1. If you can, close your eyes and imagine two bananas. Well done. You’ve just imagined the size of the Polaroid P2 Player. It’s twice as powerful as the Polaroid P1 and just as take-anywhere-able. It’s also a wearable speaker - on your wrist, over your shoulder, as a necklace, or on your head – there are no wrong choices here. The Polaroid P2 speaker is the first player in the line-up to work with all the features of the Polaroid Music App - letting you play your favorite playlists with just a spin of the analog dial. It’s powerful for its size, easily portable, colorful, and iconic in design.
Output power 20 W
The most wearable music player. -
Stereo pairing
Connect another P2 for stereo sound. -
Rechargeable battery
Provides up to 15 hours of playback time.
- Polaroid P2 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Frequency Response
- 165 - 20000 Hz
- Amplifier
- Integrated
- NFC, Bluetooth
- Yellow
- Battery
- Speaker battery rechargeable
- 22 cm x 5 cm x 9 cm
- 660.2 g
- 1-year warranty
- Product Type
- Qualcomm TrueWireless Stereo (TWS), stereo pairing
- Enclosure Colour
- Yellow
- Enclosure Material
- Nylon, polyester, iron, PP/PC, acrylonitrile butadiene styrene (ABS), thermoplastic polyurethane (TPU)
Speaker System
- Speaker Type
- Active
- 165 - 20000 Hz
- Sensitivity
- 75 dB
- Amplifier
- Integrated
- Near Field Communication (NFC), Bluetooth 5.0
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Controls
- Volume, play/pause, next track, previous track, activate Bluetooth
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Wrist strap, carabiner, USB-C charging cable
- Power Source
- Battery
- Rechargeable
- Capacity (Ah)
- 2500 mAh
- Voltage Provided
- 7.2 V
- Run Time (Up To)
- 15 hour(s)
- Recharge Time
- 4 hour(s)
- 22 cm
- 5 cm
- 9 cm
- 660.2 g
- Limited warranty - 1 year
