The Polaroid P1 is an affordable entry into the Polaroid Music universe and a very portable yet capable Bluetooth speaker. The player's physical design feels great in your hand. It also has a fabric hook in the iconic Polaroid rainbow colors and included in the box is a carabiner clip that you can use to hook the P1 player to your bag or belt. When you're hanging out with your friends you can just tap two players together to create a stereo pair, making this an awesome shared experience.
Output power 10 W
Powerful sound output to fill the room. -
Stereo pairing
Connect another P1 for stereo sound. -
Durable IPX5
Dust- and water-resistant for music on the move. -
Rechargeable battery
Provides up to 10 hours of playback time.
- Polaroid P1 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Splashproof
- Speaker Type
- Active
- Frequency Response
- 150 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth 5.1
- Red
- Battery
- Speaker battery rechargeable
- 10 cm x 4 cm x 10 cm
- 300.5 g
- 1-year warranty
- Product Type
- Stereo pairing
- Protection
- Splashproof
- Enclosure Colour
- Red
- Enclosure Material
- Polyester, polypropylene, acrylonitrile butadiene styrene (ABS), thermoplastic polyurethane (TPU)
Speaker System
- Speaker Type
- Active
- 150 - 20000 Hz
- Sensitivity
- 60 dB
- Amplifier
- Integrated
- Bluetooth 5.1
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Controls
- Volume, play/pause, next track, previous track, activate Bluetooth
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Carabiner, USB-C charging cable
- IPX5
- Power Source
- Battery
- Rechargeable
- Capacity (Ah)
- 2000 mAh
- Capacity (Wh)
- 7.2 Wh
- Voltage Provided
- 3.6 V
- Run Time (Up To)
- 10 hour(s)
- Recharge Time
- 2 hour(s)
- 10 cm
- 4 cm
- 10 cm
- 300.5 g
- Limited warranty - 1 year
