PMVmounts Universal Articulated Wall Mount Black 32"-47"
Quicklinx: B8PPWS00 Mfr#: PMVMOUNT3246SA
Marketing description is not available.
PMV Mounts PMVMOUNT3246SA - mounting kit - for flat panel
Mounting kit - wall-mountable
Mounting Components
Articulating arm, mounting plate, 2 interface brackets
Adjustable Depth
13-70 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
32"-46"
VESA Mounting Interface
200 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Mounting Pattern Size
680 x 475 mm
Max Load Weight
40 kg
Adjustable Depth
13-70 cm
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
680 x 475 mm
32"-46"
Adjustments
Tilt
Max Load Weight
40 kg
Swivel adjustment
