PMVmounts Large Universal Tilting Wall Mount for 37" to 65" Displays
Quicklinx: B74BWS00 Mfr#: PMVMOUNT2036T
PMV Mounts PMVMOUNT2036T - Wall mount for LCD / plasma panel - black satin powder coat - screen size: 32"-65"
PMV Mounts PMVMOUNT2036T mounting kit - for flat panel - black satin powder coat
Mounting kit - wall-mountable
Mounting Components
Wall mount
69 cm 42.7 cm
Tilt
-7.5° to 7.5°
Recommended Use
Flat panel
Recommended Display Size
32"-65"
VESA Mounting Interface
400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 400 mm
Max Load Weight
75 kg
Black satin powder coat
69 cm
42.7 cm
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
32"-65"
Tilt
-7.5° to 7.5°
Max Load Weight
75 kg
