Philips V-Line 226V3LSB 21.5" LCD Monitor LED Backlight 1080p VGA DVI 2- Black
Quicklinx: 7NQ5WS00 Mfr#: 226V3LSB/00
This attractive, slim display is a delight to use. Essential feature like SmartContrast that ensures rich bright images makes it a great choice!
  • LED technology
    White LED is solid state device which lights up to full, consistent brightness faster saving startup time. LED is free from mercury content which allows for eco-friendly recycling and disposal process. LED allows for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
  • SmartContrast ratio 10000000:1
    You want the LCD flat display with high contrast and most vibrant images. Philips advanced video processing combined with unique extreme dimming and backlight boosting technology results in vibrant images. SmartContrast will increase the contrast with excellent black level and accurate rendition of dark shades and colors. It gives a bright, lifelike picture with high contrast and vibrant colors.
  • 16:9 Full HD
    The Full HD screen has the widescreen resolution of 1920 x 1080p. This is high resolution of HD sources for good picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
  • Mercury free
    The Philips monitor with LED backlighting is free of mercury content, one of the most toxic natural substances which affect humans and animals. This allows for an eco-friendly display through out its life-cycle from manufacturing to disposal.
  • ENERGY STAR
    ENERGY STAR is a US EPA sponsored energy efficiency program also adopted by many other countries. ENERGY STAR certification ensures that you are buying a product which meets the latest power efficiency standards which operates with maximum power efficiency at all operational levels. The Philips monitor is certified for ENERGY STAR specifications and meets or exceeds the standard.
Philips V-line 226V3LSB - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
53.2 cm x 4.4 cm x 33.6 cm
2.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
Sync on Green, sRGB colour management, HDCP, SmartContrast
53.2 cm x 4.4 cm x 33.6 cm - without stand
2.5 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
MTBF
30,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
21 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 20.9 cm - height: 39.7 cm - weight: 2.8 kg , Without stand - width: 53.2 cm - depth: 20.9 cm - height: 39.7 cm - weight: 2.8 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
20 - 80%
