Philips Pocket Memo DPM6000 Voice Recorder
Quicklinx: DFGDWS00 Mfr#: DPM6000/00
The Pocket Memo voice recorder takes dictation to a higher level. Two microphones deliver superior audio quality for your dictations. Its robust yet lightweight stainless steel design offers perfect ergonomics for working over longer periods of time. Power saving features and a high capacity battery offer extended recording time and easy charging through a standard USB connection.
  • Two microphones for superior stereo audio recordings
    The built-in microphones always deliver superior stereo audio recordings. The crystal clear recordings are perfectly suitable for speech recognition.
  • Convenient push-button for professional recording control
    The recorder is designed for single-handed operation of all recording and playback functions, allowing easy and quick file editing (insert, overwrite, append) via convenient push-button operation.
  • Robust stainless steel casing for extra durability
    The asymmetrical and ergonomic shape fits perfectly into your hand. Its slim and lightweight design maximizes comfort, even when working over longer periods of time. The brushed stainless steel creates a robust and highly durable protective shell around the device.
  • Large color display and clear user interface for easy, intuitive operation
    The large full-color display offers sharp images, making it easier to see everything at first glance. The clear user interface is optimized for easy, intuitive operation.
  • Light sensor and battery for extended use
    The high-capacity battery can be easily charged through a standard micro USB jack. The integrated light sensor guarantees extended battery life. The smart technology adjusts the brightness of the display, ensuring that your recorder will always be ready to work when you are.
  • Priority setting for getting urgent jobs processed first
    Urgent recordings can be processed first. This makes sure important recordings are not overseen and helps you and your transcriptionists manage your workloads better.
  • High recording quality in DSS and MP3 format
    The DSS format was developed for use in digital voice recorders, allowing a high compression ratio with little loss of quality. The DSS format also allows you to store additional information in the file header, which facilitates the organization and the transcription of dictation files. The MP3 format is the common audio format for consumer audio storage, as well as a de facto standard encoding for the transfer and playback of music on digital audio players.
Philips Pocket Memo DPM6000 - voice recorder
Voice recorder flash based
5.3 cm x 12.3 cm x 1.5 cm
117 g
Playback Digital Standards
DSS, PCM, MP3
Sound Output Mode
Mono
Digital Recording Time
700 hours - SP (Standard Play), 350 hours - QP (Quality Play), 50 hours - MP3 recording, 27 hours - PCM recording, 13 hours - PCM recording (stereo)
Display
TFT - 320 x 240 - colour - 2.4"
Supported Flash Memory Cards
SDHC, SD Memory Card - up to 32 GB
Speakers
1 x speaker - built-in - 200 mW - 300 - 7500 Hz
Microphone
Two microphones - built-in - omni-directional
Rechargeable - Lithium Ion - 1000 mAh
Voice recorder
Digital Player Type
Flash based
USB Specification Version and Speeds
USB 2.0
Enclosure Material
Stainless steel
Audio Formats
DSS, PCM, MP3
Audio System
Memory Card Max Supported Size
32 GB
File System Supported
4 GB
Sound Output Mode
Mono
Functions
Digital player, digital voice recorder
Display
TFT - colour
Resolution
320 x 240
Diagonal Size
2.4"
Light sensor
Speaker System
Speakers
Driver Details
Speaker: 1 x full-range driver - 1.1"
Digital Player (Recorder)
Recording Time
Supported Bit Rate
13.7 - 705 Kbps
Microphone
Microphone Operation Mode
Omni-directional
Connector Type
Headphones (mini-phone 3.5mm) , Microphone (mini-phone 3.5mm) , USB 2.0 , Docking station
Carrying Case
Pouch
USB cable, SDHC Memory Card (4GB)
Lead-Free, RoHS 2011/65/EU
Software
Philips SpeechExec Dictate
1000 mAh
Run Time (Up To)
27 hour(s)
Recharge Time
3 hour(s)
Battery Life Details
Voice recording - Lithium Ion - up to 27 hour(s)
Microsoft Windows 7, Microsoft Windows Vista (32/64 bits), Windows 8, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks
Additional Requirements
DVD-ROM, USB port, DirectX compatible graphics card
System Requirements Details
Pentium 4 - 1 GHz - RAM 1 GB - HD 100 MB
5.3 cm
12.3 cm
1.5 cm
117 g
