The Digital Pocket Memo 9370 is always ready to take your dictation. Handy, powerful and efficient, you can easily control the latest recording technology with push buttons. With the exchangeable SD card, you have virtually unlimited recording capacity and the .dss file format produces excellent sound quality.
Completed files can be quickly transferred to a PC via a USB cable for storage or professional transcription. The Digital Pocket Memo 9370 is packaged with SpeechExec Dictate, the easy-to-use dictation download software from Philips, of course.
- Philips Digital Pocket Memo 9370 - voice recorder
- Product Type
- Voice recorder flash based
- 5 cm x 11.6 cm x 1.7 cm
- 106 g
- Playback Digital Standards
- DSS
- Sound Output Mode
- Mono
- Display
- LCD - 128 x 128 1.71"
- Clock
- Audio Specifications
- Digital Player - response bandwidth: 200 - 5500 Hz
- Supported Flash Memory Cards
- SD Memory Card
- Speakers
- 1 x speaker - built-in - 200 mW
- Microphone
- Microphone - built-in - mono
- Interface
- USB
- Battery
- 2 x AAA type
- Product Type
- Voice recorder
- Digital Player Type
- Flash based
- Interface Supported
- USB
- Audio Formats
- DSS
Audio System
- SD Memory Card
- Sound Output Mode
- Mono
- Functions
- Digital voice recorder
- Digital Player - response time: 200 - 5500 Hz
- Built-in clock
- Battery level indication, hold button, rechargeable capability, auto power off, Low Battery Alert, voice activated, microphone sensitivity selection, USB 2.0 compatibility
Display
- LCD
- Display Illumination
- Display Illumination Colour
- White
- Resolution
- 128 x 128
- Diagonal Size
- 1.71"
Speaker System
- Speakers
- Driver Details
- Speaker: 1 x full-range driver - 1.18"
Digital Player (Recorder)
- Edit Functions
- Record over, insert, erase
- Sample Rate
- 8 kHz, 12 kHz
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm) , DC power input , USB
- Included Accessories
- Carrying pouch, USB cable
- Cables Included
- 1 x USB cable
- Software
- Drivers & Utilities, Philips SpeechExec Dictate
- Battery
- 2 x AAA type
- Included Qty
- 2
- Run Time (Up To)
- 15 hour(s)
- Battery Life Details
- Digital playback - Alkaline - up to 15 hour(s)
- OS Required
- Microsoft Windows 2000 SP4, Microsoft Windows XP Home Edition SP2, Microsoft Windows Vista
- Additional Requirements
- USB port
- System Requirements Details
- Windows 2000/XP - Pentium III - 500 MHz - RAM 512 MB - HD 160 MB , Windows Vista - Pentium III - 500 MHz - RAM 1 GB - HD 160 MB
- 5 cm
- 11.6 cm
- 1.7 cm
- 106 g
