Wide open possibilities
The award-winning 49" curved 32:9 SuperWide display is like two full-size high-performance monitors in one. Productivity-enhancing features like multiple connection and Integrated KVM deliver the performance and convenience you expect.
32:9 SuperWide screen designed to replace multiscreen setups
32:9 SuperWide 49" screen with 5120 x 1440 resolution is designed to replace multiscreen setups for a massive wide view. It's like having two 27" 16:9 Quad HD displays side by side. SuperWide monitors offer the screen area of dual monitors without the complicated setup.
Effortlessly smooth action with Adaptive-Sync technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artefact-free performance at virtually any frame rate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
Built-in KVM switch to easily switch between sources
With the MultiClient Integrated KVM switch, you can control two separate PCs with one monitor-keyboard-mouse setup. A convenient button allows you to quickly switch between sources. Handy with setups that require dual PC computing power or sharing one large monitor to show two different PCs.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Tilt, swivel and height-adjust for an ideal viewing position
The Compact Ergo Base is a people-friendly Philips monitor base that tilts, swivels and height-adjusts so each user can position the monitor for maximum viewing comfort and efficiency.
MultiView enables simultaneous dual connection and view
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
1800 r curved display for a more immersive experience
Innovative curved display offers less image distortion, a wider field of view, reduced glare and more comfort for your eyes.
1800r curved display for a more immersive experience
Innovative curved display offers less image distortion, a wider field of view, reduced glare, and more comfort for eyes. -
With MultiClient Integrated KVM switch, you can control two separate PCs with one monitor-keyboard-mouse set up. A convenient button allows you to quickly switch between sources. Handy with set-ups that require dual PC computing power or sharing one large monitor to show two different PCs. -
The Compact Ergo Base is a people-friendly Philips monitor base that tilts, swivels and height-adjusts so each user can position the monitor for maximum viewing comfort and efficiency. -
32:9 SuperWide 49" screen, with 5120 x 1440 resolution, is designed to replace multiscreen setups for massive wide view. It's like having two 27" 16:9 Quad HD displays side-by-side. SuperWide monitors offer screen area of dual monitors without the complicated setup. -
Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artifact-free performance at virtually any framerate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time. -
With the ultra-high resolution Philips MultiView display you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multi-tasking. -
LowBlue Mode for easy on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
Less eye fatigue with Flicker-free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
- Philips P-line 498P9 - LED monitor - curved - 49"
- LED-backlit LCD monitor - 49"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/337936
- Energy Class
- Class G
- Power Consumption (On mode)
- 52.5 W
- Curved Screen
- USB 3.2 hub
- Panel Type
- VA
- Aspect Ratio
- 32:9
- Native Resolution
- Dual Quad HD 5120 x 1440 at 70 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 450 cd/m²
- Contrast Ratio
- 3000:1 / 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 103% NTSC, 121% sRGB, 91% Adobe RGB
- Input Connectors
- 2xHDMI, DisplayPort
- Height, swivel, tilt
- Screen Coating
- Anti-glare, 2H Hard Coating, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Black texture
- 119.4 cm x 30.3 cm x 56.8 cm
- 15.2 kg
- Environmental Standards
- TCO Certified Displays 9, ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, EPA, cETLus, CU-EAC
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 49"
- Viewable Size
- 48.8"
- Curved Screen
- Yes (1800R)
- Built-in Devices
- USB 3.2 hub
- Panel Type
- VA
- Aspect Ratio
- 32:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Pixel Per Inch
- 109
- Brightness
- 450 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 70 Hz
- Horizontal Refresh Rate
- 30 - 140 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Multilingual
- Picture by picture, Lead-free, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, SmartUniformity, Adaptive-Sync technology, EasyRead, sRGB Mode, Delta E<2 calibration
- Black texture
- 119.4 cm x 30.3 cm x 56.8 cm - with stand
- 15.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- DisplayPort (HDCP) , 2 x HDMI (HDCP) , 2 x USB 3.2 upstream , 4 x USB 3.2 downstream (fast charging) , Headphones
Mechanical
- Tilt Angle
- -5/+10
- Swivel Angle
- 40
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable
- MTBF
- 70,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- 52.5 W
- Power Consumption SDR (On mode)
- 52.5 kWh/1000h
- Power Consumption (Typical)
- 43.9 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0 Watt
- Dimensions & Weight Details
- With stand - width: 119.4 cm - depth: 30.3 cm - height: 56.8 cm - weight: 15.2 kg , Without stand - width: 119.4 cm - depth: 15.6 cm - height: 36.9 cm - weight: 10.9 kg
- Shipping Width
- 130.8 cm
- Shipping Depth
- 38.4 cm
- Shipping Height
- 55.3 cm
- Shipping Weight
- 21.22 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- 0 °C
- 40 °C
- 20 - 80%
