Philips Hue Infuse ceiling light provides white and colored light with subtle indirect light on the ceiling.
- Philips Hue White and Color Ambiance Infuse L - ceiling lamp - LED - 52.5 W - 2000-6500 K - white
- Product Type
- Ceiling lamp
- Recommended For
- Living room, bedroom
- Light Source Type
- LED
- Style
- Modern
- Light Cover Type
- Diffuser
- Dimmer
- White
- Wattage
- 52.5 W
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 3700 lumens
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Nest, Echo
- Communications Technology
- Bluetooth
- Frequency Required
- 50 - 60 Hz
- Product Type
- Ceiling lamp
- Recommended For
- Style
- Modern
- Light Cover Type
- Diffuser
- Dimmer
- Protection class I, remote controlled, app-controlled
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 52.5 W
- 2000-6500 K
- Luminous Power
- 3700 lumens
- Lifetime
- 25000 hours
Power Requirements
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Nest, Echo
- Compatible Application
- Philips Hue App
- Bluetooth
- Voice Controlled
- Indirect
- Product Material
- Metal, synthetics
- Body Colour
- White
- IP20
- Warranty
- 2 years / 30 days return
- 8.4 cm
- Diameter
- 42.5 cm
- 3.772 kg
- Shipping Dimensions (WxDxH) / Weight
- 47.6 cm x 50.2 cm x 10 cm / 4.685 kg
