Philips Hue White E27 2x Bulb Mini Kit
Quicklinx: FFRYWS00 Mfr#: 929001821601
Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
Philips Hue White Starter Kit - wireless lighting set - LED light bulb x 2 - shape: A60 - E27 - 9 W - total: 18 W - warm white light - white
Wireless lighting set
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/400273
Light Source Type
2 x LED light bulb
Supported Light Bulbs Qty
50
Total Wattage
18 W (equivalent 120 W)
Dimmer
White
Shape
A60
Socket Type
E27
Wattage
9 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
Warm white light
Luminous Power
806 lumens
Intelligent Assistant
Siri, Cortana, Google Assistant, Alexa - indirect
Communications Technology
Bluetooth, Zigbee
AC 100 - 240 V
Frequency Required
50 - 60 Hz
50
Total Wattage
Dimmer
Android compatible, iOS compatible, remote controlled, ZigBee Light Link, voice activated, upgradable firmware
Light Source
2 x LED light bulb
Shape
A60
Socket Type
E27
Wattage
9 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
9 kWh
Warm white light
Colour Rendering Index
80
Luminous Power
806 lumens
Lifetime
25000 hours
Switch Cycles
50000
Instant full light
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub
Included
Hub Compatibility
Philips Hue Bridge
Bluetooth, Zigbee
Voice Controlled
Indirect
Body Colour
White
Power adapter, network cable, Hue bridge
Package
Box
Warranty
2 years
Dimensions & Weight Details
Light bulb height: 110 mm x diameter: 61 mm , Wireless bridge height: 26 mm x diameter: 88 mm
-20 °C
45 °C
