A perfect fit for spotlights, GU10 bulbs upgrade your home lighting. These bulbs are suitable for standard GU10 fittings and offer all the benefits of smart lighting.
Efficient illumination
This light bulb delivers 400 lumens of brightness while consuming only 4.3 W of energy, ensuring effective and energy-efficient lighting. -
Smart home integration
Compatible with the Philips Hue Bridge, it allows for seamless integration into smart home systems, enhancing connectivity and control. -
Flexible color temperature
The adjustable color temperature ranges from warm to cool white light, providing options for various moods and activities. -
Voice-controlled convenience
Easily manage your lighting with voice commands through intelligent assistants, making daily operations simpler and hands-free. -
Dimmable capabilities
The dimmable feature allows users to adjust the brightness to suit different settings, promoting comfort and ambiance.
- Philips Hue White ambiance - LED spot light bulb - GU10 - 4.3 W - warm to cool white light - 2200-6500 K (pack of 6)
- Recommended For
- Living room, bedroom
- Light Source Type
- Packaged Quantity
- 6 (specifications are for single item)
- Socket Type
- GU10
- Wattage
- 4.3 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Warm to cool white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 400 lumens
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Communications Technology
- Bluetooth, Zigbee
- Packaged Quantity
- Recommended For
Light Source
- Socket Type
- GU10
- Wattage
- 4.3 W
- E
- Energy Consumption per 1000h
- 5 kWh
- Power Factor
- 0.5
- 2200-6500 K
- Luminous Power
- 400 lumens
- Dimmable
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Compatible Application
- Philips Hue App
- Supported Host Device Platform
- iOS, Android
- Bluetooth, Zigbee
- Voice Controlled
- Indirect
- Warranty
- 2 years
- 5 cm
- 5 cm
- 5.8 cm
- Diameter
- 50 mm
- Length
- 58 mm
- 50 g
