Live in the future with this Philips smart lighting starter kit. By connecting to the included Bridge hub, you’ll be able to adjust your lights from your phone or tablet. The three included GU10 spotlight bulbs produce both white and coloured lighting to match any mood, and have a lifetime of 25,000 hours so they won’t need changing for quite some time. Set up a schedule to have them come on at designated moments, or if you’ve got the Apple HomeKit or Amazon Echo smart speaker, you can turn on the lights with a simple voice command.
Please note, you’ll need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
- Smart light starter kit – control the lighting remotely
- White and coloured bulb – choose from 16 million shades
- Spotlight fitting with 25,000 hour lifespan
- Schedule a timer to turn lights on automatically
- Works with Apple HomeKit and Amazon Alexa
Be creative with millions of colors
Play with light and choose from millions of colors to instantly change the look and atmosphere of your room. -
Sync lights with music and films
Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. -
Light up your gaming
Lift your gaming experience to another level. Discover the amazing things you can do with Philips Hue. -
Wake up and go to sleep naturally
Philips Hue will help get you out of bed the way you like it, helping you to start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise and helps you to wake up naturally, instead of being woken up by the loud sound of an alarm clock. -
Installation-free dimming
Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.
- Philips Hue White and Color Ambiance Starter Kit - wireless lighting set - LED spot light bulb x 3 - GU10 - 6.5 W - total: 19.5 W - 16 million colours - 2000-6500 K
- Product Type
- Wireless lighting set
- Light Source Type
- 3 x LED spot light bulb
- Supported Light Bulbs Qty
- 50
- Total Wattage
- 19.5 W
- Dimmer
- Socket Type
- GU10
- Wattage
- 6.5 W
- Energy Efficiency Class
- A
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 250 lumens
- Intelligent Assistant
- Alexa - indirect
- Platform
- Hue
- Communications Technology
- Zigbee
- Product Type
- 50
- Total Wattage
- 19.5 W
- Dimmer
- Android compatible, iOS compatible
Light Source
- Socket Type
- GU10
- Wattage
- 6.5 W
- A
- 2000-6500 K
- Luminous Power
- 250 lumens
- Lifetime
- 25000 hours
- Upgradable firmware, instant full light
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Included
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Communications Type
- Product-to-product
- Zigbee
- Alexa
- Voice Controlled
- Indirect
- Included Accessories
- Power adapter, wireless bridge, network cable, dimmer switch, battery
- Warranty
- 2 years
- Dimensions & Weight Details
- Light bulb height: 70 mm x diameter: 50 mm , Wireless bridge height: 26 mm , Dimmer switch - width: 35 mm x depth: 11 mm x height: 92 mm
- -10 °C
- 45 °C
