Philips hue combines brilliant LED light with intuitive technology. It will surely change the way you use light. Forever. Experiment with shades of white, from invigorating blue/white to cozy yellow/white. Or play with all the colors in the spectrum. Hue can wake you up. Help protect your home. Relive your favorite memories. Improve your mood. Even keep you informed about the weather. Not just stunning, hue is smart too. And it's tailored for you.
Be creative with millions of colors
Play with light and choose from millions of colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger. -
Sync lights with music and films
Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. -
Wake up and go to sleep naturally
Philips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm light helps you to unwind, relax and prepare your body for a good night's sleep.
- Philips Hue White and Color Ambiance - LED light bulb - shape: B39 - E14 - 6.5 W - 16 million colours - 2200-6500 K (pack of 2)
- Light Source Type
- LED light bulb
- Packaged Quantity
- 2 (specifications are for single item)
- Shape
- B39
- Socket Type
- E14
- Wattage
- 6.5 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Colour Temperature
- 2200-6500 K
- Dimmable
- Voltage Required
- AC 220 - 240 V
- Packaged Quantity
Light Source
- LED light bulb
- Shape
- B39
- Socket Type
- E14
- Wattage
- 6.5 W
- A+
- Energy Consumption per 1000h
- 6.5 kWh
- 2200-6500 K
- Dimmable
- Lifetime
- 25000 hours
- Instant full light, remote controlled, Android compatible, iOS compatible
Power Requirements
- Voltage Required
- AC 220 - 240 V
- Warranty
- 2 years
- Diameter
- 39 mm
- Length
- 117 mm
