Philips Hue is your personal wireless lighting system that lets you easily control your light and create the right ambience for every moment. Bring your smart home to life with the most connected light in the world.
This starter kit includes 3 Hue Light Bulbs, a Bridge and a Dimmer Switch.
Be creative with colors
Play with light and choose from 16 million colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger. -
Sync with music and films
Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. Download the third-party apps and discover the amazing things you can do with Philips Hue. -
Light up your gaming
Lift your gaming experience to the next level. Download the third party apps and discover the amazing things you can do with Philips Hue. -
Wake up and go to sleep
Philips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep. -
Create your ambiance
Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of summer sun or the ice cool daylight of winter.
- Philips Hue White and Color Ambiance Starter Kit - wireless lighting set - LED light bulb x 3 - shape: A60 - B22 - 10 W - total: 30 W - 16 million colours - 2000-6500 K
- Product Type
- Wireless lighting set
- Light Source Type
- 3 x LED light bulb
- Supported Light Bulbs Qty
- 50
- Total Wattage
- 30 W (equivalent 180 W)
- Dimmer
- Shape
- A60
- Socket Type
- B22
- Wattage
- 10 W
- Wattage Equivalent
- 60 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 806 lumens
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Apple HomeKit, Hue
- Voltage Required
- AC 220 - 240 V
- Product Type
- 50
- Total Wattage
- Dimmer
- Wireless, Android compatible, iOS compatible, ZigBee Light Link
Light Source
- Shape
- A60
- Socket Type
- B22
- Wattage
- 10 W
- 60 W
- A+
- Power Factor
- 0.5
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 806 lumens
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Upgradable firmware, instant full light, Android compatible, iOS compatible, voice control, controlled via Wi-Fi, remote controlled, light scheduling
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 1 x CR2450
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Included
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Voice Controlled
- Indirect
- Included Accessories
- Power adapter, wireless bridge, network cable, dimmer switch
- Package
- Box
- IEEE 802.15.4
- Warranty
- 2 years
- Dimensions & Weight Details
- Dimmer switch - width: 35 mm x depth: 11 mm x height: 92 mm , Light bulb height: 110 mm x diameter: 62 mm , Wireless bridge height: 26 mm
- -10 °C
- 45 °C
