Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
Wake up and go to sleep naturally
Philips Hue will help get you out of bed the way you like it, helping you start your day feeling refreshed. The light brightness increases gradually mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day, the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night sleep. -
Create your ambiance with warm white to cool daylight
Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun, or the ice cool daylight of winter. -
Relax, read, concentrate and energize with light recipes
Light influences your mood and behavior. Philips Hue can help you to customize your daily routines into moments you can enjoy. Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Stay focussed with finely tuned bright white light. Or put your feet up and relax with a soft glow of white light for the perfect end of the day. -
Smart control, home and away
With the Philips Hue iOS and Android apps you can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late. -
Set timers for your convenience
Philips Hue can make it seem like you're home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on. -
Installation free dimming
Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation -
Control with your voice
Philips Hue works with Amazon Alexa, Apple HomeKit and Google Home, powered by the Google Assistant, to allow you to control your lights with your voice. Turn your lights on and off. Dim to the desired brightness for a perfect ambiance. Even recall pre-set scenes, change colors and more - all without lifting a finger. -
Wirelessly controllable LED bulb
This LED bulb is wirelessly controllable if you connect it to the Philips Hue bridge for smart control or to the Philips Hue dimmer switch. -
Dimmable only with Philips Hue compatible devices
This product is only dimmable if connected to the Philips Hue bridge or to a Philips Hue compatible device -
Perfect fit
The Philips Hue white ambiance GU-10 lamp is designed as a perfect retrofit solution, so it blends in seamlessly with your existing spot lighting fixtures. This makes it a smart and energy-efficient alternative to traditional halogen spots
- Philips Hue White ambiance - LED spot light bulb - GU10 - 5 W - cool daylight/warm white light - 2200-6500 K (pack of 2)
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/391948
- Light Source Type
- Packaged Quantity
- 2 (specifications are for single item)
- Socket Type
- GU10
- Wattage
- 5 W
- Wattage Equivalent
- 50 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Cool daylight/warm white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 350 lumens
- Dimmable
- Intelligent Assistant
- Cortana, Google Assistant, Alexa
- Platform
- Apple HomeKit
- Voltage Required
- AC 220 - 240 V
- Packaged Quantity
Light Source
- Socket Type
- GU10
- Wattage
- 5 W
- 50 W
- G
- Energy Consumption per 1000h
- 5 kWh
- 2200-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 350 lumens
- Dimmable
- Lifetime
- 15000 hours
- Switch Cycles
- 15000
- Instant full light, Android compatible, iOS compatible, voice control, remote controlled, controlled via Bluetooth
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Apple HomeKit
- Package
- Hanging box
- Warranty
- 2 years
- Diameter
- 50 mm
- Length
- 58 mm
- 48 g
- -20 °C
- 45 °C
