Suitable for most light fixtures, these two E27 smart LED bulbs offer cool light, warm light and all the shades in between as well as instant wireless dimming.
Set the right mood with warm to cool white light
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs. -
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device. -
Control lights with your voice
Philips Hue works with voice assistants when paired with a compatible device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp. -
Get the perfect light recipes for your daily activities
Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
- Philips Hue White ambiance - LED light bulb - shape: A60 - E27 - 8 W - warm to cool white light - 2200-6500 K (pack of 2)
- Light Source Type
- LED light bulb
- Packaged Quantity
- 2 (specifications are for single item)
- Shape
- A60
- Socket Type
- E27
- Wattage
- 8 W
- Wattage Equivalent
- 75 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Warm to cool white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 1100 lumens
- Dimmable
- Intelligent Assistant
- Indirect
- Platform
- Hue
- Communications Technology
- Zigbee
- Voltage Required
- AC 220 - 240 V
- Packaged Quantity
Light Source
- LED light bulb
- Shape
- A60
- Socket Type
- E27
- Wattage
- 8 W
- 75 W
- F
- Energy Consumption per 1000h
- 8 kWh
- Power Factor
- 0.5
- 2200-6500 K
- Luminous Power
- 1100 lumens
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Android compatible, iOS compatible
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Zigbee
- Voice Controlled
- Indirect
- Warranty
- 2 years
- 6 cm
- 6 cm
- 11 cm
- Diameter
- 60 mm
- Length
- 110 mm
- 72 g
