What's Required? - Nothing! This product works out of the box with the free ‘Philips Hue Bluetooth’ app. Simply screw in your new bulb and connect to the Bluetooth app for in room smart lighting control!
Designed For Full Rooms: With a brightness of 350 lumen, these smart LED bulbs provide the right amount of light to fill areas of your living room or kitchen.
Dimmable Cool To Warm White Light - Play with 50,000 shades of tuneable warm to cool white light to put you in the mood to work, play, or relax. Start your morning off on the right foot with cool, energising bright white light, or settle down for the night with golden tones.
Control Lights With Your Voice - Works with all Echo smart speakers/displays and Google Nest devices for hands-free voice control (Philips Hue Bridge (sold separately) is required for Echo 1st Gen and Echo Dot 1st Gen).
Unlock Your Homes Full Potential - Add a Philips Hue Bridge (sold separately, optional) and unlock full home control, either when you’re home or away.
Set the right mood with warm to cool white light
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs. -
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device. -
Control lights with your voice
Philips Hue works with voice assistants when paired with a compatible device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp. -
Get the perfect light recipes for your daily activities
Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
- Philips Hue White ambiance - LED spot light bulb - GU10 - 4.3 W - warm to cool white light - 2200-6500 K (pack of 3)
- Light Source Type
- Packaged Quantity
- 3 (specifications are for single item)
- Socket Type
- GU10
- Wattage
- 4.3 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Warm to cool white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 350 lumens
- Dimmable
- Intelligent Assistant
- Cortana, Google Assistant, Alexa, Apple HomeKit - indirect
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Packaged Quantity
Light Source
- Socket Type
- GU10
- Wattage
- 4.3 W
- G
- Energy Consumption per 1000h
- 4.3 kWh
- Power Factor
- 0.5
- 2200-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 350 lumens
- Dimmable
- Lifetime
- 15000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Bluetooth, Zigbee
- Voice Controlled
- Indirect
- Warranty
- 2 years
- 5 cm
- 5 cm
- 5.8 cm
- Diameter
- 50 mm
- Length
- 58 mm
- 153 g
- Shipping Dimensions (WxDxH) / Weight
- 7.2 cm x 14.6 cm x 17.4 cm / 214 g
- -20 °C
- 45 °C
