Philips Hue White 10.5W A60 E27 2-Pack Starter Kit
Quicklinx: GVZDWS00 Mfr#: 929002469201
Get your smart lighting system started with this Starter kit, which includes two smart bulbs with soft white light and the Hue Bridge. It's a complete kit for custom control over your home lighting and all its great features.
  • White
  • Up to 1100 lumens
  • Soft white light
  • Simple setup
  • Hue Bridge included
Philips Hue White Starter Kit - wireless lighting set - LED light bulb x 2 - shape: A60 - E27 - 9.5 W - soft white light - 2700 K - white
Wireless lighting set
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/403542
Light Source Type
2 x LED light bulb
Supported Light Bulbs Qty
50
Dimmer
White
Shape
A60
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
75 W
Energy Efficiency Class
F
Colour of Illumination
Soft white light
Colour Temperature
2700 K
Luminous Power
1055 lumens
Intelligent Assistant
Alexa - indirect
Platform
Apple HomeKit
Communications Technology
Bluetooth, Zigbee
AC 100 - 240 V
Frequency Required
50 - 60 Hz
50
Dimmer
Light Source
2 x LED light bulb
Shape
A60
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
75 W
F
Energy Consumption per 1000h
10 kWh
Power Factor
0.5
Soft white light
Colour Temperature
2700 K
Luminous Power
1055 lumens
Lifetime
25000 hours
Switch Cycles
50000
Upgradable firmware, Android compatible, iOS compatible
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub
Included
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit
Compatible Application
Philips Hue App
Bluetooth, Zigbee
Alexa
Voice Controlled
Indirect
Body Colour
White
Power adapter, network cable
Warranty
2 years
Dimensions & Weight Details
Light bulb height: 110 mm x diameter: 61 mm - 73 g , Wireless bridge height: 2.6 cm x diameter: 8.8 cm
17.6 cm x 14.6 cm x 14 cm / 760 g
-10 °C
45 °C
