The rectangle Surimu ceiling panel features a soft, diffused glow of colorful light. Perfect for living rooms and bedrooms, the Surimu ceiling panel is easy to install and sits flush with the ceiling, filling the room with color.
Get the perfect light recipes for your daily activities
Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind. -
Set the right mood with warm to cool white light
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs. -
Create a personalized experience with colorful smart light
Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theater, enhance your home decor with color accents, and much more.
- Philips Hue White and Color Ambiance Surimu - ceiling light panel - LED - 600 x 600 mm - 60 W - 16 million colours/warm to cool white light - 2000-6500 K - square - white
- Product Type
- Ceiling light panel - square
- Recommended For
- Kitchen, living room, bedroom, home office
- Standard Panel Size
- 600 x 600 mm
- Light Source Type
- LED
- Dimmer
- White
- Wattage
- 60 W
- Wattage Equivalent
- 100 W
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 3350 - 4150 lumens
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Hue
- Communications Technology
- Bluetooth
- Voltage Required
- AC 220 - 240 V
- Product Type
- Recommended For
- 600 x 600 mm
- Shape
- Square
- Dimmer
- Protection class I, Android compatible, iOS compatible, remote controlled, controlled via Bluetooth, app-controlled
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 60 W
- 100 W
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Required
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Compatible Application
- Philips Hue App
- Bluetooth
- Voice Controlled
- Indirect
- Product Material
- Metal, synthetics
- Body Colour
- White
- IP20
- Warranty
- 60 days money back guarantee
- 60 cm
- 60 cm
- 4.8 cm
- 5.7 kg
- Shipping Dimensions (WxDxH) / Weight
- 70 cm x 12 cm x 70.5 cm / 8.13 kg
